Switched to a more congested path?
- Switched to a more congested path?
- « Previous
- 1
- 2
- Next »
Re: Switched to a more congested path?
18-10-2016 12:59 PM - edited 18-10-2016 1:04 PM
I had exactly the same - a small "red curtain" starting on Friday. I was also having some connection problems yersterday, although only on my laptop, other devices appeared to be connecting normally.
Very odd as I'm on FTTP which is usually "clean". So after an afternoon spent trying to debug my network, at around 5pm there was a sudden red "spike" on the graph to about 20% packet loss; after that everything is clear!
19-10-2016 9:21 AM
OK, thanks folks. Again, very helpful.
We think we've spotted the cause of the problem (seems that one of the interfaces on pcl-cr02 is misbehaving).
We're going to take it out of service early tomorrow morning. It would be appreciated if those of you still seeing the packet loss can avoid disconnecting/reconnecting so we can see if the issue clears once the change is made.
19-10-2016 10:00 AM
It seems I got caught up in all this, I suspected my Hub-One to be at fault so I changed setup a few days ago to a combination of (a trusted) HG612 Modem and Hub-One as Router.
Hub-One seems to be loosing dsl more than I would like which Is causing my long line to be very Unstable.
Graphs with Red Line match my recent session drop.
04:47:19, 19 Oct. (158326.660000) PPPoE is down after 2637 minutes uptime [Disconnected]
04:47:16, 19 Oct. (158324.310000) PPP LCP Send Termination Request [PPPoE PADT received]
@bobpullen If I change back to my Hub-One In a week or so and it still looses the DSL connection, would it be possible to get another Hub-One from you to test if it is related to chip specific problems by chance? or maybe the vdsl side is just borked!
I don't see anything odd in the stats (posted below) so far, but then I'm no expert.
xdslcmd info --stats xdslcmd: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 6266 Kbps, Downstream rate = 46464 Kbps Bearer: 0, Upstream rate = 2000 Kbps, Downstream rate = 40000 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 9.3 16.8 Attn(dB): 24.5 0.0 Pwr(dBm): 11.2 1.4 VDSL2 framing Bearer 0 MSGc: -6 118 B: 138 62 M: 1 1 T: 0 17 R: 8 16 S: 0.1101 0.9907 L: 10684 646 D: 16 1 I: 147 80 N: 147 80 Q: 16 0 V: 12 0 RxQueue: 27 0 TxQueue: 9 0 G.INP Framing: 18 0 G.INP lookback: 9 0 RRC bits: 0 24 Bearer 1 MSGc: 90 -6 B: 0 0 M: 2 0 T: 2 0 R: 16 0 S: 10.6667 0.0000 L: 24 0 D: 1 0 I: 32 0 N: 32 0 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 397921 OHFErr: 2 5 RS: 2020517360 4268235 RSCorr: 24555 2243 RSUnCorr: 0 0 Bearer 1 OHF: 10861820 0 OHFErr: 0 0 RS: 65170553 0 RSCorr: 18 0 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 5940042 0 rtx_c: 916 0 rtx_uc: 9 0 G.INP Counters LEFTRS: 18 0 minEFTR: 39989 0 errFreeBits: 106425054 0 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 535509463 0 Data Cells: 366595450 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 2 5 SES: 0 0 UAS: 24 24 AS: 174474 Bearer 0 INP: 45.00 0.00 INPRein: 0.00 0.00 delay: 0 0 PER: 0.00 16.90 OR: 0.01 58.67 AgR: 40252.99 2059.15 Bearer 1 INP: 2.50 0.00 INPRein: 2.50 0.00 delay: 0 0 PER: 16.06 0.01 OR: 47.81 0.01 AgR: 47.81 0.01 Bitswap: 109202/109202 7/7 Total time = 1 days 28 min 18 sec FEC: 24555 2243 CRC: 2 5 ES: 2 5 SES: 0 0 UAS: 24 24 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 13 min 18 sec FEC: 142 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 134 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 28 min 18 sec FEC: 276 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 24 hours 0 sec FEC: 7457 11 CRC: 0 3 ES: 0 3 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Since Link time = 2 days 27 min 53 sec FEC: 24555 2243 CRC: 2 5 ES: 2 5 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 #
19-10-2016 11:40 AM - edited 19-10-2016 11:49 AM
For what ever reason it seams i lost connection this morning around 4.50am to 5.00am
Any idea what that may have been bob ? ..hmm i think i may have been affected by a bt outage.
20-10-2016 7:42 AM
@bobpullen: It looks like whatever was done (about 1am) worked. I still go through (pcl-bng01 and) irb.16.pcl-cr02.plus.net, and (at least) the BQM red curtain has lifted. Thanks!
20-10-2016 10:11 AM
That would explain the complaints of "the internet's broken" from those in the house still working /gaming just before 1am this morning. By the time they had woken me up it was back
20-10-2016 10:19 AM
Yep, looks to have done the trick
Apologies for the trouble.
21-10-2016 7:55 PM
So why are you still taking down stuff when you say it's fixed @bobpullen
Logs...
If you can be bothered to reply that is, old chap!
- « Previous
- 1
- 2
- Next »
