Switched to Plusnet 3 Weeks ago, Speed and Latency still slow
- Re: Switched to Plusnet 3 Weeks ago, Speed and Lat...
19-05-2019 10:47 PM
I would be grateful if someone from PlusNet Help Team could reply please. I switched from TalkTalk 3 weeks ago on a 38/10 connection Modem sync 37999/9999 with Ping latency of 8ms, before that I was on BT 52/10, Syncing at 51999/9999.
My Welcome letter said I would get a speed of between 62Mbps - 80Mbps, although no Guaranteed Minimum could be given at the time of order ??, even so,the Guaranteed Min should be between these figures, and certainly not dipping below 60.
I have a preferred Modem of a Draytek V130 and V2830 Router, but at the moment I have left the PlusNet one fitted. the UL sync is on the money at 20000, but the DL is only 45000. Ping times 28Ms
My SNR on TT was also 3DB, its now 6DB
I seem to have been put on Interleave on DL, this would explain the high Ping times, I have attached a screen shot of the VDSL Stats from my V130 Modem on the day of the switch.
I have refrained from posting following a read from Johno`s Post about waiting for 2 weeks for the DLM to stabilise, but nothing has changed.
My first post was really a heads up to Triceratops, which replicates pretty much exactly my issue, in the hope that in two weeks I too would have better DL speeds ping times.
I have preformed all the usual tests like Direct connection to master test socket, I have no internal Phone wire.
One request I would like is for a GEA test, please, thank you.
I look forward to hearing from you soon,
Re: Switched to Plusnet 3 Weeks ago, Speed and Latency still slow
20-05-2019 11:21 AM - edited 20-05-2019 11:21 AM
Hi @Jimbowe
Thanks for getting back to us.
I'm sorry to see you're still experiencing slower than expected speeds.
There are times we can't provide a guaranteed speed until a line has been provisioned although I believe we'd make you aware of this before submitting the order which you'd have to acknowledge before going ahead.
I can see your minimum guaranteed speed is 51.7mbps, however this is generally only used for contract purposes as we'll be happy to investigate a speed fault that's below your current estimates which looks to be between 60mbps to 80mbps.
At a guess I'd say that this increase in the signal to noise ratio(SNR) is the cause for the speed drop. If that's the case it appears that this may have been masking a fault with your service as your speeds without 3dB are below where they should be.
Having said that it's difficult to advise definitively as our tests aren't showing any issues and as you've already done the troubleshooting we'd ask I'd recommend raising a fault to us Here so we can arrange an engineer to investigate this.
I've attached a copy of your GEA Test below:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEU[redacted] |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 45.6 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 443.2 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From 10:00 to 22:00 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 14 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-05-07T11:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 45.2 Mbps | 45.6 Mbps | 45.4 Mbps |
Up Stream Line Rate | 19.9 Mbps | 20.0 Mbps | 19.9 Mbps |
Up Time | 787.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-05-20T10:46:24.237+01:00 | 2019-05-20T11:01:24.237+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
If you can nudge us over here once you've raised the fault we'll be happy to pick this up as soon as we can.
Hope this helps.
20-05-2019 5:11 PM
Thanks for the quick response Gandalf,
I was wondering where you got the 51.7 Guaranteed speed from, but then I found an Email in Spam, sent just on 2 weeks explaining it, it also goes on to say my current line speed is 78Mb ? (I wish). Is the Guaranteed Speed actual Download Speed or Modem Sync speed ?
I appreciate the speed in which you are raising this as a fault with a view to arrange an Engineer visit (TalkTalk where not that quick !), however, before I do, could someone possibly explain a couple of things on my GEA test please.
Interference Pattern - Regular Interference Observed Daily
Interference Duration Longest Occurrence - From 10:00 to 22:00
Interference Location - Customer Premise
Radio Frequency Ingress - Not Detected
Repetitive Electrical Impulse Noise - Not Detected
Cross Talk - Not Detected
What I see here is that the problem is in my house, a lot if Interference daily. So the 443 metres of Copper Cable from the Green Cab to my master Socket is fine, No REIN, RF or Crosstalk. The PN Router sits 10 Inches form the MS, no other Internal Wiring, apart from structured cabling for my Home LAN, would a BT 8500 Dect phone cause problems, that sits above the Router. How does the test differentiate between street and home cabling.
I had a fault whilst with TT, again slow speeds, but having talked to the Openreach Engineer, I was apparently on Two wires from Different pairs, I basically wasn't on a twisted pair, Crosstalk would have been terrible, but the test shows fine, just thought I would mention it
Thanks.
20-05-2019 5:30 PM
Cheers for getting back to me.
The current line speed is basically a profile on your account from a bygone era from when we had traffic prioritisation. It should always match the IP profile of the line via automated delta reports we receive, sometimes it can be a bit slow to update.
It used to refer to the line's sync speed, but recently it changed to throughput/download speed on a wired connection.
No problem, as you've done the troubleshooting I figured there wasn't much else to suggest so without further ado...
Ah fair, to be honest I'm not entirely sure what the interference in the test could be referring to, or how the test differentiates between the line and what's in your home, I reckon I'd struggle to definitively find that last part out.
I wouldn't have thought electrical interference you have from everyday devices would cause a speed drop like you're experiencing and also not cause other symptoms like an intermittent connection.
Hope this helps.
22-05-2019 5:57 PM
Thanks for the reply Gandalf, there pretty much my feelings also, so have clicked that fault link you sent me and a Ticket has now been raised.
Really appreciate the help so far !!
22-05-2019 6:19 PM
No problem, I've added a reply to your fault ticket which you can view and reply to from here: https://www.plus.net/wizard/?p=view_question&id=190426203 If you can nudge us over here once you've responded we'll be happy to pick this back up as soon as we can
22-05-2019 6:33 PM
Using a portable analog radio (aka a tranny radio) you will pickup all sorts of radiated noise over a range of frequencies emitted by your power cubes, tv, and anything else electronic/electrical.
These signals can be induced (received) by incorrect wiring carrying vdsl/adsl signals (remember this is wireless technology), or via the wiring in the house (ie conductive).
Also while it may show as internal, if its conducted/radiated from an external source, how would a GEA test know the location of the source?
Tracking this type of problem is very difficult, solution, FTTP, then in all probability any Radio Frequency Interference is more than likely to be internal (picked up on bad ethernet wiring, poor shielding of equipment), unless you are living next door to a radio transmitter.
on 22-05-2019 8:43 PM - last edited on 23-05-2019 7:14 AM by Mav
If the engineer finds the problem is with your internal wiring, your equipment, the condition of your property or the Openreach network has been damaged within the boundary of your property by things like building or garden works or if no fault is found, you will receive a charge of £65 to cover the cost of the engineer. This charge will also apply if you miss the appointment or you cancel without giving us 2 working days' notice.
Just a bit worried about this £65 charge, specifically the if no fault is found bit. Based on this post and the GEA test, are we in agreement that there is a fault on my line ?, need to feel a bit of reassurance if Openreach are unable to find a problem that I wont be hit with a bill and still have a slow line
Moderator's note by Mike (Mav): Excess white space removed.
22-05-2019 9:02 PM
Just picking up on a point you raised about bad ethernet wiring, I have a 24 port Switch in the garage, which floods all the rooms in the house with CAT6, with one Uplink to the Router in the living Room, 6 inches from the filtered Master socket, the phone is plugged in there also, 12 inches above, the cable comes in from the street right into the back of the MS, virtually no cable length on the BT side in my house. Could that Cat6 uplink cable induce Noise onto the BT Copper side of things if indeed the structured cabling was acting like an Antenna for Noise. (Its not by the way, its a sound job, ). And yes FTTP all the way, don't think my exchange is accepting orders yet Alas, I only have a portable DAB Radio,
Thanks for replying.
22-05-2019 10:34 PM - edited 22-05-2019 10:43 PM
I would suggest not running power - phone - ethernet cables in close proximity to each other, especially on long runs..
22-05-2019 10:41 PM
Appreciate the concern, yes I think we can agree there’s definitely a fault somewhere. If the 1st engineer doesn’t find a fault with your service and things remain the same we’d likely just arrange a 2nd engineer to investigate further.
We’ll only charge you a call out fee passing it on from our suppliers if it’s absolutely valid, that process can generally take up to 90 days following a fault investigation closing as we robustly defend all engineer charges before/if accepting any.
Hope this helps.
22-05-2019 11:45 PM
23-05-2019 12:05 AM
Thanks.
23-05-2019 10:51 AM
Morning @Jimbowe
I've booked the appointment updated the ticket with the engineer date and time.
Let us know how it goes
Thanks,
MoR
28-05-2019 10:51 PM
Hello Gandalf / MOR
Openreach Engineer came this morning at 08:10, and confirmed that there are no wiring faults in my house, or on the Copper line, and using his test equipment he too, could only train the line to 51Mb at my Master Socket. He went to the Green Cab where the DLM is and plugged into the Fibre Port and could only get 60MB, apparently should have been 80Mb, he told me the fibre port was faulty, don't know weather he plugged me into another one, maybe the report he sends you will give more info. He told me the line is now training again, probably another 10 days, in which he said the speed will increase. I am a bit dubious about that, as I thought a DSL line always trains down, could it train up 20Mb in 10 days ?. He also suggested there may be a cap on my line or port ?. I would have thought that a port on a DLM would service a number of houses ?. I will wait with anticipation for the next 10 days to see what happens. Can you tell with a new GEA test if I am on another port ?
One positive is that I seem to be on Fastpath for Download now, and my ping times have improved by 10ms. Is G-inp enabled on a Re-Train ?. I have now installed my Draytek V130 Modem and will show below the VDSL Stats. Shouldn't the Attainable Rate be a lot higher, say 70Mb, then the Actual Rate increases over the 10 day Re-Train, or will the Attainable Rate increase over 10 days ?, this confuses me as the Attainable is lower than the Actual, but on the VDSL Test early on in the post on Day one they are reversed ?.
Any comments would be greatly appreciated (A lot of questions I know )
Thanks.
