Switched from standard Fibre to Superfast and see no speed change
Jcdek
I have recently switched from Standard fibre to superfast fibre.
Having run a BT speedtest I can see I am only getting 33Mbps DL and 7 UL.
UL line profile should be upto 20Mbps.
I had 55Mbps DL for a long time but now have seen a biggest decrease.
The odd thing is that the DL has synced at 39999Kbps almost as if it is still on the 10/40 profile.
Can somebody please look into this for me?
66 REPLIES 66
Fixes: 286
Re: Switched from standard Fibre to Superfast and see no speed change
Sounds like the upgrade might not have happened.
Can you post the DSL stats from the router Helpdesk page. (redact any personal infomation)
Jcdek
Unfortunately I cant at this time.
Is there something specific you need to know?
Jcdek
Does this help at all (taken this morning).
Aspiring Legend
Fixes: 162
@Jcdek You are definitely on an 80/20 package - see your upload profile, but something is not right, both your up and down achieved speeds suggest you are stuck on 40/10 speeds, hence why @MisterW asked for your Help Desk data. You are not on a fixed IP by any chance?
Mustrum
Fixes: 73
Is your line capable of supporting higher speeds? Post the results when you put your phone number in the BTW DSL Checker - making sure you hide your number.
Do you have a filtered Master Socket, or are you using dangly filters?
Jcdek
Many thanks for the reply.
No, not on a fixed IP.
Aspiring Legend
Fixes: 162
OK - we definitely need your Help Desk data then.
Jcdek
Thanks for the reply,
Does this help?
Master socket is the BT fitted double filtered faceplate.
Aspiring Legend
Fixes: 162
It does in a way - it says in effect you are too far from the cab to benefit from 80/20.
Jcdek
I had 55Mbps for a long time. We have 2x Fibre lines to the property (both in the same cable just different pairs) the other gets 62Mbps.
Jcdek
The other thing to note is that I currently have 8.0dB Downstream SNRM at 39999 kbps.
When I had 54395 kbps I was at 3 dB.
Aspiring Legend
Fixes: 162
OK - so the Help Desk would tell us more - please.
Jcdek
That's not that straight forward as from this morning I swapped the hub one for another router. I pretty sure I can give you all the info you could get from the helpdesk stats.
To be clear though the speed drop happened a month ago now hence why I decided to switch to a different router to see if it could help. The speed has been consistently at and around 33Mbps.
I should add that also coupled with a number of main power cuts this week I have disconnected the router today as well although the exchange doesn't seem to have been bothered about it since my speed has stayed the same.
Hope this helps.
Stats
xdslctl info --stats
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    0
Last initialization procedure status:   0
Max:    Upstream rate = 9596 Kbps, Downstream rate = 46309 Kbps
Bearer: 0, Upstream rate = 9596 Kbps, Downstream rate = 39999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        7.8             6.0
Attn(dB):        21.0            0.0
Pwr(dBm):        12.7            6.1
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              26
B:              81              237
M:              1               1
T:              0               40
R:              8               16
S:              0.0000          0.7879
L:              11120           2579
😧              8               1
I:              90              127
N:              90              254
Q:              8               0
V:              4               0
RxQueue:                136             0
TxQueue:                34              0
G.INP Framing:          18              0
G.INP lookback:         31              0
RRC bits:               0               24
                        Bearer 1
MSGc:           90              -6
B:              0               0
M:              2               0
T:              2               0
R:              16              0
S:              10.6667         0.0000
L:              24              0
😧              1               0
I:              32              0
N:              32              0
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               1348907
OHFErr:         43              26
RS:             1685878536              1669486
RSCorr:         309045          109
RSUnCorr:       0               0
                        Bearer 1
OHF:            1705649         0
OHFErr:         0               0
RS:             10233526                0
RSCorr:         10              0
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         204980424               0
rtx_c:          20468           0
rtx_uc:         107             0
                        G.INP Counters
LEFTRS:         3               0
minEFTR:        39995           0
errFreeBits:    16710009                0
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    2107171127              0
Data Cells:     134212064               0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             3               14
SES:            1               0
UAS:            30              30
AS:             27405
                        Bearer 0
INP:            52.00           0.00
INPRein:        1.00            0.00
delay:          0               0
PER:            0.00            7.90
OR:             0.01            32.36
AgR:            40368.53        9628.56
                        Bearer 1
INP:            2.50            0.00
INPRein:        2.50            0.00
delay:          0               0
PER:            16.06           0.01
OR:             47.81           0.01
AgR:            47.81   0.01
Bitswap:        17899/17899             21/21
Total time = 7 hours 37 min 15 sec
FEC:            309045          109
CRC:            43              26
ES:             3               14
SES:            1               0
UAS:            30              30
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 15 minutes time = 7 min 15 sec
FEC:            3168            0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 15 minutes time = 15 min 0 sec
FEC:            7899            0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 7 hours 37 min 15 sec
FEC:            309045          109
CRC:            43              26
ES:             3               14
SES:            1               0
UAS:            30              30
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 1 day time = 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Since Link time = 7 hours 36 min 45 sec
FEC:            309045          109
CRC:            43              26
ES:             3               14
SES:            1               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
Aspiring Legend
Fixes: 162
Thanks for that - although I have problems interpreting those stats - too much superfluous data, to my mind. There is nothing there (other than the FEC count, which looks high for 7 hours) to explain this - the only conclusion I can draw from the data is that at some point a month ago, your circuit suffered an accident which upset it badly.
Hopefully, @MisterW  or @Mustrum might be able to throw more light on it, but I suspect you may have to get Plusnet to involve BT here.
Please note, I'm no expert on FTTC, but I have been around long enough to spot problems.
