Switched from standard Fibre to Superfast and see no speed change
- Re: Switched from standard Fibre to Superfast and ...
Re: Switched from standard Fibre to Superfast and see no speed change
01-06-2021 4:06 PM
No further update. Anything I can do to get the attention of somebody from Plusnet???
01-06-2021 4:24 PM
Thanks for your post @Jcdek and apologies for the delayed staff response.
From what I can see your line's banded at 40mbps "Downstream: 0.128M-40M with Retransmission (High). Upstream: 0.128M-20M with no error protection" so I've arranged for your line to be reset now which should go through within 3 working days. Let us know if you haven't seen an increase after then so we can investigate further.
01-06-2021 5:14 PM
Many thanks Gandalf for your response and swift action.
03-06-2021 5:31 AM
Hi Gandalf,
I am now synced at 46.7Mbps but when I carry out the BT Speedtest I still only ever get 33.8Mbps each time.
Any idea what's going on?
03-06-2021 8:55 AM
Hi @Jcdek, thanks for getting in touch and I'm sorry to hear you're continuing to have speed issues as of recent. I can confirm when testing your connection from this side currently we're seeing 46.7Mbps download reaching the router with no signs of errors or underlying issues. Can I ask then, since your profile was corrected, have your turned the router off and back on at all? If then then I'd recommend giving this a go.
As always, I'd recommend when running any speed tests to make sure there's nothing using the connection at the time as this can skew results and if you're still seeing lower speeds on the BT Speed test then I'd recommend trying another as sometimes the speed test site can be the cause. Let us know how it goes.
03-06-2021 4:27 PM
Thanks BD for the reply.
I did the speed tests at 5am this morning. There wasn't anybody else online and this was before and then after having rebooted the modem.
I'll try it again tomorrow morning on an different speed test site and see what I get.
04-06-2021 8:54 AM
04-06-2021 5:48 PM
Hi Gandalf,
Thanks again for your reply.
I should have clarified earlier my home network is all wired so speedtests are done via the modem directly to the master socket.
I'll try the speedtester you linked to tomorrow morning and report back my findings although I did run the 'Speedtest.net' one this morning and still got the same 33Mbps.
04-06-2021 7:54 PM
Does this user have a fixed IP address ... ?
04-06-2021 8:16 PM
Hi Townman,
I don't believe so, I've certainly never asked for one.
If you can please tell me how I check this I will gladly get the required info.
04-06-2021 8:51 PM
User portal - broadband, but I'm not assured that it will show for sure. I have a static IP address but I do not see the configuration page. If you are not sure then you are unlikely to have one, which eliminates one known gremlin which causes exactly this issue.
05-06-2021 7:30 AM - edited 05-06-2021 7:43 AM
Hi Gandalf,
So in my opinion there is clearly an issue here and this is why I think so.
Checking my line stats this morning shows a resysnc this morning with my DL connection now at 50.5Mbps and the DL SNRM at 4.9dB (this was not done by me).
I carried out the Think Broadband speedtest as advised and here are the results.
I should add, this is via the modem, no other devices on and wired directly to the master socket (BT dual faceplate type, there are no cable extensions).
05-06-2021 9:34 AM
The next suspect has to be exchange backhaul congestion!
05-06-2021 9:49 AM
Thanks Townman,
But what does that mean and what can I do about it?
05-06-2021 10:02 AM
It is the network capacity between the exchange and the internet.
There is nothing that you can do with it, mentioning it is a "hint" asking staff to consider it, in case it has not been examined. It is a place of last resort. Given that the line stats look good, one need to look elsewhere for the problem. One usually suspects Wi-Fi performance, then retransmission over heads due to high line error rates, but they do not appear to apply here. After that one has to examine other parts of the network ... and the performance of the end points - your PC and the speed test server.
Out of interest which browser are you using and have you compared results with different ones?
