Switched from standard Fibre to Superfast and see no speed change
- Re: Switched from standard Fibre to Superfast and ...
29-05-2021 11:18 AM
I have recently switched from Standard fibre to superfast fibre.
Having run a BT speedtest I can see I am only getting 33Mbps DL and 7 UL.
UL line profile should be upto 20Mbps.
I had 55Mbps DL for a long time but now have seen a biggest decrease.
The odd thing is that the DL has synced at 39999Kbps almost as if it is still on the 10/40 profile.
Can somebody please look into this for me?
Re: Switched from standard Fibre to Superfast and see no speed change
29-05-2021 12:36 PM
Sounds like the upgrade might not have happened.
Can you post the DSL stats from the router Helpdesk page. (redact any personal infomation)
29-05-2021 2:03 PM
Unfortunately I cant at this time.
Is there something specific you need to know?
29-05-2021 2:06 PM
Does this help at all (taken this morning).
29-05-2021 2:38 PM
29-05-2021 2:49 PM
Is your line capable of supporting higher speeds? Post the results when you put your phone number in the BTW DSL Checker - making sure you hide your number.
Do you have a filtered Master Socket, or are you using dangly filters?
29-05-2021 3:02 PM
Many thanks for the reply.
No, not on a fixed IP.
29-05-2021 3:04 PM
OK - we definitely need your Help Desk data then.
29-05-2021 3:04 PM
Thanks for the reply,
Does this help?
Master socket is the BT fitted double filtered faceplate.
29-05-2021 3:06 PM
It does in a way - it says in effect you are too far from the cab to benefit from 80/20.
29-05-2021 3:06 PM
I had 55Mbps for a long time. We have 2x Fibre lines to the property (both in the same cable just different pairs) the other gets 62Mbps.
29-05-2021 3:15 PM
The other thing to note is that I currently have 8.0dB Downstream SNRM at 39999 kbps.
When I had 54395 kbps I was at 3 dB.
29-05-2021 3:17 PM
OK - so the Help Desk would tell us more - please.
29-05-2021 4:02 PM
That's not that straight forward as from this morning I swapped the hub one for another router. I pretty sure I can give you all the info you could get from the helpdesk stats.
To be clear though the speed drop happened a month ago now hence why I decided to switch to a different router to see if it could help. The speed has been consistently at and around 33Mbps.
I should add that also coupled with a number of main power cuts this week I have disconnected the router today as well although the exchange doesn't seem to have been bothered about it since my speed has stayed the same.
Hope this helps.
Stats
xdslctl info --stats
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 9596 Kbps, Downstream rate = 46309 Kbps
Bearer: 0, Upstream rate = 9596 Kbps, Downstream rate = 39999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 7.8 6.0
Attn(dB): 21.0 0.0
Pwr(dBm): 12.7 6.1
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 81 237
M: 1 1
T: 0 40
R: 8 16
S: 0.0000 0.7879
L: 11120 2579
😧 8 1
I: 90 127
N: 90 254
Q: 8 0
V: 4 0
RxQueue: 136 0
TxQueue: 34 0
G.INP Framing: 18 0
G.INP lookback: 31 0
RRC bits: 0 24
Bearer 1
MSGc: 90 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 10.6667 0.0000
L: 24 0
😧 1 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 1348907
OHFErr: 43 26
RS: 1685878536 1669486
RSCorr: 309045 109
RSUnCorr: 0 0
Bearer 1
OHF: 1705649 0
OHFErr: 0 0
RS: 10233526 0
RSCorr: 10 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 204980424 0
rtx_c: 20468 0
rtx_uc: 107 0
G.INP Counters
LEFTRS: 3 0
minEFTR: 39995 0
errFreeBits: 16710009 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 2107171127 0
Data Cells: 134212064 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 3 14
SES: 1 0
UAS: 30 30
AS: 27405
Bearer 0
INP: 52.00 0.00
INPRein: 1.00 0.00
delay: 0 0
PER: 0.00 7.90
OR: 0.01 32.36
AgR: 40368.53 9628.56
Bearer 1
INP: 2.50 0.00
INPRein: 2.50 0.00
delay: 0 0
PER: 16.06 0.01
OR: 47.81 0.01
AgR: 47.81 0.01
Bitswap: 17899/17899 21/21
Total time = 7 hours 37 min 15 sec
FEC: 309045 109
CRC: 43 26
ES: 3 14
SES: 1 0
UAS: 30 30
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 7 min 15 sec
FEC: 3168 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 7899 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 7 hours 37 min 15 sec
FEC: 309045 109
CRC: 43 26
ES: 3 14
SES: 1 0
UAS: 30 30
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 7 hours 36 min 45 sec
FEC: 309045 109
CRC: 43 26
ES: 3 14
SES: 1 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
29-05-2021 4:22 PM
Thanks for that - although I have problems interpreting those stats - too much superfluous data, to my mind. There is nothing there (other than the FEC count, which looks high for 7 hours) to explain this - the only conclusion I can draw from the data is that at some point a month ago, your circuit suffered an accident which upset it badly.
Hopefully, @MisterW or @Mustrum might be able to throw more light on it, but I suspect you may have to get Plusnet to involve BT here.
Please note, I'm no expert on FTTC, but I have been around long enough to spot problems.
