Switched To Fibre Today - Speeds Exactly The Same??
markjozy
I moved from many years of ADSL to Unlimited Fibre (FTTC) today, I received an email just after midnight stating "Your product change is now complete" Cheesy
So this evening I set up my new Hub One as instructed & after a few minutes it was connected & away I went (or so I thought!!) Embarrassed
When I logged into the router settings I checked the stats which were (and still are) :
Line state: Connected
Connection time: 0 days, 00:29:26
Downstream: 6.104 Mbps
Upstream: 979 Kbps
 This is the exact same stats I had on ADSL - I logged onto the member centre & checked my line speed which showed as :
Telephone number:
01924******
Phone exchange:
BATLEY
Estimated line speed:
40Mb (This may vary between 41.3Mb and 57.4Mb) - Checked on 2017-02-06 13:10:46
Current line speed:
40 Mb
 So I'm obviously set up for fibre as the line speed used to show as 5Mb.
After a couple of hours with no change to the speed (I expected it to start high & probably drop as it settled down?) I tried connecting to the master socket to eliminate any internal wiring (it was connected to my main PC in my office upstairs) but the stats were exactly the same Cry
I even restored the router to factory settings in case I'd messed something up but nothing's changed.
Could a member of staff please look into this for me & advise me on my next move - I did try phoning but gave up after an hour on hold.
 I will try again tomorrow unless I get an answer here first, it just seems strange that the sync speeds are exactly the same as I had before the switch to fibre - it's as if I'm still on ADSL but if so, why the confirmation email?
Incidentally, it's probably not relevant to this problem but I received a second email 3 hours ago to say my router has been dispatched today (I received it last Friday - 4 days ago)?? Sad
Any help would be much appreciated.
Thanks in advance Thumbs Up
rongtw
Fixes: 12
Re: Switched To Fibre Today - Speeds Exactly The Same??
Looks like you have fallen foul of the PN Emails Sad
you may be on FTTC on the PN system but not actually physically connected , hopefully one of the staff will pick this up and check for you  Thumbs Up
markjozy
Thanks rongtw Thumbs Up
 I did think it was a bit strange as the confirmation email arrived at 00.58 on the day I was meant to switch - I was expecting it sometime during the day.
When I check my number on the BT Wholesale ADSL Checker it still says "There is an open order on your line which is due to complete on 21-Feb-2017?
It seems one email was premature & the other about hardware was a week late Huh
Hopefully a staff member can put me out of my misery soon Buck2
BTW: If the switch to fibre takes place, would my old setup on ADSL (Belkin ADSL2+ router) stop working as it still worked as normal before I swapped it for the Hub One?
Fixes: 162
I've just double checked your order and unfortunately it's hit a delay, we've been asked to check back on the 24th so we should have more info at that point.
 Chris Parr
 Plusnet Staff
markjozy
Thanks @Chris I actually got through on the phone at the same time you replied Thumbs Up
I now know that "Your product change is now complete" means just that - my contract has changed to fibre but not necessarily my line Sad
Here's hoping it's just something simple like an engineer delay & not demand outweighing supply.
I'll see what happens by the 24th & keep my fingers crossed Wink
markjozy
Could a staff member please try resetting my profile as I think it may be stuck Undecided
Since I checked this lunchtime, I've been syncing at around 20Mbps down & 2Mbps up but after running a few speed tests, my download speed was still around the 5.8Mbps mark & 0.8Mbps upload!
I tried rebooting the router & even resorted to a factory reset - this is my current sync speed :-
DSL Line Status
Connection Information
Connection time: 0 days, 00:44:38
Downstream: 21.56 Mbps
Upstream: 2 Mbps
After running a few more speed tests just now, they were all around the same speed - the obvious difference being the upload speed has increased.
262127815
I also got a strange email this afternoon which said :-
The order we placed to change your upload speed has completed.
Your upload speed is now 2Mbit/s.
Kind regards,
Plusnet Customer Support
That's great but no mention of an upload speed increase?? Shocked
Hopefully someone will be able to shed some light on this for me.
Thanks Thumbs Up
