Supported Routers, router/modems
Davie
Hello,
Looking to upgrade the router we got when we upgraded to Fibre but would like to get one that's supported by Plusnet but cannot find a list of ones supported by them. We have six of us in the house so it can get heavily used. Not to worried if its a router or a modem/router but a combined unit will get rid of the box on the wall (which will please my wife)
I did buy a TP-Link AC-3200 a few months ago but the unit was faulty and sent back. Anything else along these lines that we should consider?
Cheers in advance
Davie
8 REPLIES 8
Re: Supported Routers, router/modems
They only support the ones they supply
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
rongtw
Fixes: 12
There are several that people use here , a good guide can be found here http://www.kitz.co.uk/routers/index.htm
I have a Asus DSL-AC68u which works well , even people have a BT home hub from Ebay
NorthPole
Fixes: 6
+1 for the Asus DSL-AC68U.
Fixes: 62
I have the Billion 8800NL which works well and also allows monitoring via dslstats
ksennitt
I'm considering a TP-Link Archer VR900 as heard reasonable reports
Fixes: 62
except according to Kitz (from the earlier link) doesn't provide line stats which makes diagnosis of problems much harder
toekneem
Have both a Draytek 2860 and a Fritzbox 7490 and both work with no probs at all. Draytek has 6 eth ports but Fritzbox does have the phone side covered as well, but as already mentioned most ISP's I know will only ever support the modem/Router that they supply.
Davie
Thanks for all the replies, I'll have a read up on the routers mentioned above
Thanks again
Davie
