Supported Routers, router/modems
- Re: Supported Routers, router/modems
13-10-2016 1:37 PM
Hello,
Looking to upgrade the router we got when we upgraded to Fibre but would like to get one that's supported by Plusnet but cannot find a list of ones supported by them. We have six of us in the house so it can get heavily used. Not to worried if its a router or a modem/router but a combined unit will get rid of the box on the wall (which will please my wife)
I did buy a TP-Link AC-3200 a few months ago but the unit was faulty and sent back. Anything else along these lines that we should consider?
Cheers in advance
Davie
13-10-2016 1:56 PM
To be is to do - Kant
do be do be do - Sinatra
13-10-2016 3:37 PM
There are several that people use here , a good guide can be found here http://www.kitz.co.uk/routers/index.htm
I have a Asus DSL-AC68u which works well , even people have a BT home hub from Ebay
14-10-2016 2:27 PM
+1 for the Asus DSL-AC68U.
14-10-2016 2:41 PM
I have the Billion 8800NL which works well and also allows monitoring via dslstats
14-10-2016 3:38 PM
I'm considering a TP-Link Archer VR900 as heard reasonable reports
14-10-2016 3:41 PM
except according to Kitz (from the earlier link) doesn't provide line stats which makes diagnosis of problems much harder
14-10-2016 5:53 PM
Have both a Draytek 2860 and a Fritzbox 7490 and both work with no probs at all. Draytek has 6 eth ports but Fritzbox does have the phone side covered as well, but as already mentioned most ISP's I know will only ever support the modem/Router that they supply.
15-10-2016 1:24 PM
Thanks for all the replies, I'll have a read up on the routers mentioned above
Thanks again
Davie
