Superfastastrophe!
BaaMoo
Superfastastrophe!
Hi Forumers.  I got 'upgraded' to unlimited fiber extra this morning and very briefly it was excellent.  Things did not stay that way. At one point I was testing at 65up/19down and soon after 10/18 and now I'm down at 4/15.  I've raised a call with support and plugged into the master socket as instructed.  Changed the microfilter, changed the router, changed the cable, tried it both wireless and wired.
Any thoughts?
Fixes: 36
Re: Superfast calamity!
Have you done a quiet line test with a corded phone ? Dial 17070?
BaaMoo
I have not tried that, I will do so in the morning, although I did have a listen to the dial tone earlier and it seemed fine.  Thanks for the reply.
BaaMoo
Re: Superfastastrophe!
Update,  There has been very little progress on the problem. It does seem that everyone who is connected to the same cabinet as I am is experiencing problems.
Fixes: 541
Hello there and welcome to the community.
First of all, I love your thread title.
With regards to your speeds, it looks like an engineer went out yesterday and found a problem with your internal wiring, fitting a new master socket to rectify that.
How are things today?
BaaMoo
Hi Gandalf,
Thanks for the response.  Things seem much improved since the visit of the openreach engineer, who seemed very thorough and professional.  The download speeds still fall short of the anticipated speed but they are now in the region when it could be down to settling after a reset.  I will monitor the speeds an update as a I get further information.
Hopefully I'll be able to change it to superfastatic soon.
BaaMoo
Sadly I have to report that not much seems to have changed.  After initially feeling positive I noticed a drop in performance and performed the speed tests (by the book).  Please see attached results.
Fixes: 541
Our tests aren't detecting any further issues now, but from the speed tests you've completed there definitely seems to be a problem somewhere as the actual sync rate is 80mbps.
Are you experiencing problems using multiple devices?
BaaMoo
Yes, but I won't try to brush my teeth and mow the lawn simultaneously again.
But otherwise, I'm only my own today so I'm not sure. I did wonder if there was just some problem speed testing, but I did a real world download test and it backs up the data.  At least I think so, maybe I've not done the sums proper.
Thanks for your help.
Fixes: 541
Cheesy
It's probably worth checking with another device to see if the download speed is slow there too.
No problems Smiley
BaaMoo
I understand what you mean now.  Yes my phone displays similar results as the desktop machine.   It's on the WiFi though.  I'll get hold of a laptop later and test on the ethernet on that.   Streaming services seem pretty fine to me, YT, Netflix, Spotify, but downloads and speed tests are poor.
What do you make of that?
Some sort of over prioritisation?
Fixes: 541
That's quite strange. I doubt it's related to traffic prioritisation as we've recently removed that for Unlimited usage products.
Let us know how the testing using a laptop goes.
BaaMoo
Here are the results from the test on the laptop.  I didn't do the Tap3 test thingy.  Hope this is helpful.
BaaMoo
FYI:
NOTE: This is not my speedtest or even a PLUSNET user.
This user is connected to the same cabinet as I am.  There is much grumbling round these here parts.
BaaMoo
Any further thoughts on this Gandalf?
I reckon that if it looks like a duck and quacks like a duck it's a throughput issue.
I get 70 plus down at 0630 and less than 10 at peak times.
