Super fast extra slowing to snails pace and long disconnections
Tangoed66
Over the past week or so we have regularly experienced incidences where speeds have dropped to almost a standstill then eventually picked up. The last two nights after having several slow downs over the day we have lost broadband all together, it seems to happen between midnight and 1am, right when I’m trying to watch Netflix! The dial tone is fine with no noise etc, the broadband is still disconnected in the morning and we have to turn off the router to get it back up and running. There are no reported incidents for Plusnet or Openreach. I’m not sure what can be done to sort it out but it’s very frustrating!
13 REPLIES 13
SammyM
Fixes: 96
Re: Super fast extra slowing to snails pace and long disconnections
Hello @Tangoed66,
Thanks for getting in touch and welcome to the forums. I am sorry to hear this is happening to your connection, our tests are not locating any potential faults externally.
However I can see the connection drop where you have advised you have had to reset it. Please can you advise;
  • Does the decrease in speed occur on both a wired and wireless connections? or solely wireless?
  • If there anything that comes on at around that time specifically such as heating etc?
 Sammy M - Sheffield Team
Tangoed66
Hi @SammyM
We have a Velop mesh system which has a wired connection to the router, our wifi comes from the velop and is turned off on the router, when the connection drops the wifi network is still available and shows connected on our devices but is not connected to the internet so the problem is definitely not originating there. I have experienced severe slow downs usually mid afternoon and evening and the total disconnections seem to happen late at night, there is nothing set to come on or switch off around this time, we have been leaving the heating on a low setting all night so it is off timer. The telephone dial tone sounds normal when the broadband is off.
Hopefully you can suggest something to get this sorted.
Heather
MatthewWheeler
Fixes: 479
Thanks for getting back to us with the information.
Can you confirm that when you experience a drop in connection if the lights on the router change?
In addition is it possible to connect directly to the router to see if you're having the same issue?
 Matthew Wheeler
Tangoed66
Hi @MatthewWheeler
When the speed slows right down the light stays blue, I think there may be a very quick disconnection at this point too as I sometimes get the you are not connected to the internet message in my web browser. When the internet disconnection is for any period of time then the light is red with a red or flashing b.
Unfortunately we have no means to connect direct to the router as there is only a desktop in another room, connected by ethernet to a satellite Velop node, plus internet TVs, iPads and iPhones, as I said earlier the Velop wifi network is still available to use during the disconnection but is obviously not connected to the internet, the wired ethernet from the satellite is also not able to access the internet.
Hope that helps
Heather
EmilyD
Fixes: 117
Hi @Tangoed66,
Thank you for confirming how the connection is looking from your side - I'm sorry for any inconvenience that these issues are causing you.
I've tested your line but the test hasn't picked up any problems from here:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 70.2 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 549.2
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Retransmission Low
Time Stamp 2019-02-05T18:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 72.2 Mbps 73.4 Mbps 72.7 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 762.0 Sec 900.0 Sec 899.4 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-02-18T15:34:05Z 2019-02-18T15:49:05Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Please can you run through our troubleshooting guides here and let us know how you get on.
 Emily D
Tangoed66
Hi @EmilyD
I have already been through the troubleshooting suggestions and everything was fine, the fault has been intermittent and the connection has been pretty stable since yesterday, we didn't experience the disconnections last night and I was able to watch my Netflix programme till the end! Smiley I will try to jump straight back on to let you know if/when it crops up again.
Heather
OskarPapa
Fixes: 65
Hi @Tangoed66, thanks for getting back to us.
It's great to hear that the issues seem (fingers crossed) to be resolved.
Please don't hesitate to get back in touch, should you need any further assistance.
Tangoed66
So my speeds have been okay for a couple of weeks but the last few days I am experiencing problems again, I have attached a screen shot of the speeds I have been getting on my iPad today!
MasterOfReality
Fixes: 57
hi @Tangoed66
Your router is syncing at 73.2Mbps and no faults have been identified on the circuit ;
Test OutcomePass
Test Outcome CodeGTC_FTTC_SERVICE_0000
DescriptionGEA service test completed and no fault found .
Main Fault LocationOK
Sync StatusIn Sync
Downstream Speed73.2 Mbps
Upstream Speed20.0 Mbps
Appointment RequiredN
Fault Report AdvisedN
NTE Power StatusPowerOn
Voice Line Test ResultPass
Bridge TapNot Detected
Repetitive Electrical Impulse NoiseNot Detected
Estimated Line Length In Metres549.2
Upstream Rate AssessmentVery Good
Downstream Rate AssessmentVery Good
Interference PatternNot Detected
Service ImpactNo Impact Observed
Home Wiring ProblemNot Detected
Downstream Policing Discard Rate0.0
Customer Traffic LevelUpstream and Downstream Traffic Detected
TechnologyVDSL
Profile Name0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Retransmission Low
Are you only noticing speed issues on your Wireless devices such as this Ipad, or are you also seeing speed issues on Wired connections?
Thanks,
MoR
Tangoed66
I don’t have any direct wired connections, I have Ethernet connection to the main Linksys Velop node, this is connected wirelessly to the secondary node from which I have an Ethernet connection to my iMac. I am seeing the problem on all devices including buffering on my internet tv.
MasterOfReality
Fixes: 57
Thanks for that @Tangoed66
Can you plug a Laptop/PC/other directly into your router via Ethernet and run a speed test please so we can get an indicative speed test done?
I'm afraid we can;t offer tech support on your Home Mesh system, so we need to bypass it and see if there is anything wrong.
Thanks,
MoR
Tangoed66
I forgot to also mention that my phone line is intermittently noisy and I see ‘ line cord interruption’ regularly ( as in several times per day)on my phone screen
MasterOfReality
Fixes: 57
Hi @Tangoed66
As you can see in the GESA test above, the line test has passed.
To be sure, I have just ran a stand alone WLR3 Test - this has also passed with no fault being found.
Thanks,
MoR
