Suggestions / is this normal
moansalot13
Help
while checking out hub stats etc - spotted the following (plusnet Hub one)
image 1 shows hub home page with connected devices - nil
image 2 shows network connections - 1 connection on lan port ie this lap top which connected by ethenet to hub
question is why is it not showing up on hub home page as a connected Ethernet device ?  any ideas or am i worrying about nothing
cheers in advance
Fixes: 31
Re: Suggestions / is this normal
Both images show nothing connected.
Where do you see a pic lan connected?
moansalot13
pic 2 shows lan 4 a connection  at 100 mbps   admittedly no description / mac address etc
lan 1-3  nothing
Lappy is connected to lan port 4 on router
moansalot13
FOR INFO - I just replaced the plusnet one hub with a BTHH 5 which i had in reserve
hh5   home page is correctly showing a network connection  on ethernet ( not doing this on plusnet hub)
and on network connections it is also showing a lan connection  on port 4 with mac address ( though device is shown as  unknown - again showing more info than plusnet hub)
bobminors
Try doing a factory reset on the Hub One. Paperclip in the little hole in the back, keep it pressed in until the lights stop changing.
moansalot13
Thanks i'll try that
moansalot13
Reset the plusnet hub one
it's now picking up network connected devises correctly  - many thanks for your suggestion / tip
Fixes: 31
That does not mean something is attached. Just suggests you are on an older version of software, or perhaps it's a HH4 !
moansalot13
hi back on Plusnet hub one
after the reset it's picking up the network connections now ( it was working previously  - though not showing the info)
The hub software is stating it was updated on 1/10/16  so I'm assuming this is latest version  - however what is slightly concerning is that it was apparently an automatic/remote update -  I received the hub mid August and I have not instigated any  software update ( unless i did it in my sleep) to the best of my knowledge.
Anyone know if there is an auto update setting that can be turned off in the hub - not keen on the auto update functionality
Assistance / guidance appreciated
cheers
moansalot13
Apologies
Temporary hub was definitely a BT HH5 version A - it wasn't that hub I was having issues with  - refer post a few moments ago
Fixes: 31
Both BT and PN hubs get automatically updated centrally from time to time, nothing you can switch off unless you put some other software on it.
So all in all, nothing to worry or moan about, the original router just forgot the name of your pic, or it was switched off - a reboot from time to time if you see a problem cures many issues..
bobminors
All the Hub Ones got an automatic firmware update around the end of last month - you should now be on version 4.7.5.1.83.8.226
It's benign.
Fixes: 183
Moderator's note by Mike (Mav): I have changed the fix to bobminors as per message #5.
Forum Moderator and Customer
