Suddenly on 40/2 from 80/20
akashi
I have been on 80/20 since 2013.
In the past few days I am constantly receiving speed within 40/2.
Can someone please check this fault.
Thanks.
rongtw
Fixes: 12
Re: Suddenly on 40/2 from 80/20
what does it say here ? http://speedtest.btwholesale.com  after doing the second test further diagnostic
test
Fixes: 167
I'm just looking in to this now and will reply again shortly.
 Chris Parr
 Plusnet Staff
Fixes: 167
Unfortunately it seems your line had incorrectly been changed to a lower speed, this has been corrected and you should be back to normal speeds tomorrow. Let us know if you have any issues after that.
 Chris Parr
 Plusnet Staff
akashi
I have tested my speed this morning I am achieving speeds of 40/20Huh
Fixes: 167
Can you try a disconnect/reconnect and see how it's looking now?
 Chris Parr
 Plusnet Staff
akashi
Thanks Chris.
Speed is now reaching around 70Mb. BT Speed Test isn't showing the results for some reasons.
I find it strange the speed was changed 'incorrectly', will I be receiving any refund for the inferior service?
