Sudden upload speed drop
homecottage
My internet connection has suffered a sudden drop in upload speed, and the SNR margin is showing as 0dB.
Previously I had a fairly consistent 9.22Mb/S until some time between 23:54 30th and 15:53 31st of March when it fell to 7.64.
I don't have a record of the SNR before that date, so I don't know if the download SNR margin has changed. but it is now about 14.4dB.
There is also a gap in my Whitebox stats for the duration of this period, as if the line was disconnected.
Any ideas?
Thank you
Edit: DSLstats output added. Connected by an Ethernet cable.
(Old date, as that is all I have access to ATM)
Fixes: 67
Re: Sudden upload speed drop
Diagnostics aren't showing any issues. Have you definitely ruled out WiFi as a potential factor?
 Adam Walker
homecottage
Hello Adam
Do you mean I should disable all WiFi, in case that is getting into the line?
James
Fixes: 412
Hi James.
I'd plug a computer or laptop into the router using an ethernet cable.
This will help narrow down where the issue lies.
EDIT: I see you're referring to your sync rate coming into the router.
In this case I'd try the steps here.
Hope this helps.
homecottage
Hello Gandalf
I tried that.
Exactly the same, but I'm not surprised, as I have no telephone extension sockets.
I'm wondering if something was changed with all the Openreach activity that has been going on since the FTTC cabinet was installed?
James
homecottage
Full stats as of today.
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    0
Last initialization procedure status:   0
Max:    Upstream rate = 8332 Kbps, Downstream rate = 60299 Kbps
Bearer: 0, Upstream rate = 8343 Kbps, Downstream rate = 40000 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        14.5            6.1
Attn(dB):        20.7            0.0
Pwr(dBm):        12.2            2.9
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              26
B:              178             237
M:              1               1
T:              0               42
R:              12              16
S:              0.1424          0.9063
L:              10727           2242
D:              16              1
I:              191             127
N:              191             254
Q:              16              0
V:              2               0
RxQueue:                22              0
TxQueue:                11              0
G.INP Framing:          18              0
G.INP lookback:         11              0
RRC bits:               0               24
                        Bearer 1
MSGc:           90              -6
B:              0               0
M:              2               0
T:              2               0
R:              16              0
S:              10.6667         0.0000
L:              24              0
D:              1               0
I:              32              0
N:              32              0
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               283460
OHFErr:         0               18
RS:             75412208                11903206
RSCorr:         25              25
RSUnCorr:       0               0
                        Bearer 1
OHF:            167906          0
OHFErr:         0               0
RS:             1007066         0
RSCorr:         0               0
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         18              0
rtx_c:          19              0
rtx_uc:         0               0
                        G.INP Counters
LEFTRS:         2               0
minEFTR:        39991           0
errFreeBits:    1645162         0
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    207459469               0
Data Cells:     156181          0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             0               12
SES:            0               0
UAS:            28              28
AS:             2697
                        Bearer 0
INP:            47.00           0.00
INPRein:        0.00            0.00
delay:          0               0
PER:            0.00            9.55
OR:             0.01            26.79
AgR:            40055.74        8370.38
                        Bearer 1
INP:            2.50            0.00
INPRein:        2.50            0.00
delay:          0               0
PER:            16.06           0.01
OR:             47.81           0.01
AgR:            47.81   0.01
Bitswap:        107/107         89/89
Total time = 45 min 25 sec
FEC:            25              25
CRC:            0               18
ES:             0               12
SES:            0               0
UAS:            28              28
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
FailedRetr:     0
FailedFastRetr: 0
Latest 15 minutes time = 25 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
FailedRetr:     0
FailedFastRetr: 0
Previous 15 minutes time = 15 min 0 sec
FEC:            1               1
CRC:            0               2
ES:             0               2
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           N/A
FailedRetr:     N/A
FailedFastRetr: N/A
Latest 1 day time = 45 min 25 sec
FEC:            25              25
CRC:            0               18
ES:             0               12
SES:            0               0
UAS:            28              28
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
FailedRetr:     0
FailedFastRetr: 0
Previous 1 day time = 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
FailedRetr:     0
FailedFastRetr: 0
Since Link time = 44 min 57 sec
FEC:            25              25
CRC:            0               18
ES:             0               12
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
FailedRetr:     0
FailedFastRetr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
Fixes: 234
Moderators Note.
Moved to fibre from broadband
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 67
Thanks for giving that a try. I'd raise a fault next over at http://faults.plus.net
Give us a shout here when you have.
 Adam Walker
homecottage
Hello Adam
Ticket raised as suggested.
Regards
James
homecottage
Status since 30th April
"Your support request has been escalated to the correct team for review."
Fixes: 67
I've just replied to the fault ticket on your account.
Here's a direct link: https://www.plus.net/wizard/?p=view_question&id=173562421
 Adam Walker
homecottage
Now down to 7Mb/s.
How low does it have to go before something happens?
Fixes: 13
Hi @homecottage and thanks for coming back to us.
I've checked your connection and the upload is syncing at around 8.2mb/s which is very similar to the speed we measured as part of this fault here:
As my colleague Adam advised at the time, we're limited to what we can do at this stage as there are no faults apparent on our supplier's network or any other tangible reason for the drop in upload speed which remains only slightly lower than the estimates for your line.
We're still happy to arrange for an engineer to visit your premises (and the external infrastructure) however as Adam advised previously, this may not yield any further progress re: your upload speed.
Let us know how you'd like to proceed.
Best wishes,
Dave
 Dave G
