Sudden complete loss of internet
tddwhite
Last night internet suddenly dropped. States is connected to router but no internet. Asks for further login details which takes me to hub manager- just tells me can't connect to broadband. Asks me to configure my hub (??) or reset it. Trying to sign in and configure the hub just tells me there's no internet. Resetting router doesn't help.
DSL connection. No landline to test. Line originally set up by engineer. Problem present on all devices. Present for over 12hrs now. No reply on the formal plusnet troubleshooter.
Any help/suggestions please?
Every now and then in the past I've had this problem for about a minute, but then it resolves by going on the hub manager.
Nobody
Re: Sudden complete loss of internet
Happened to me to.  Cut off around 05:30 on Friday morning.  The modem syncs, but not authenticating.  Swapped my own modem/router to the Openreach modem/Thomson router supplied, same thing.  Logged fault at 7am in the morning, called when home from work, no movement.  Agent added a couple of notes on my ticket. Informs me that the next update will be next Wednesday!
I'm reading a similar case on a business account that has been out for three weeks here https://community.plus.net/t5/Business/Concentrator-not-reachable/td-p/1339861
God knows how long it will take for Plusnet to fix my connection.
Fixes: 239
@tddwhite From what I can see you've got a incorrect password in your router which is stopping you from getting online. Can you try another reset?
@Nobody If you can PM me your username I'll get that looked into.
 Matthew Wheeler
Nobody
PM'ed. Thanks, Matthew
tddwhite
Do you mean reset the hub manager password? Will this email me a new password?
Fixes: 239
@tddwhite If you reset it using the pinhole on the back that should get you online.
 Matthew Wheeler
tddwhite
Yes messing around with the hub manager passwords has sorted it thank you.
Fixes: 239
Glad to hear it's sorted.
 Matthew Wheeler
Nobody
Hi Matthew,
Did you have a chance to look at the fault on my line please?
Keith67
Hi,   Anyone like me in Glasgow area got complete loss of internet ?  I have done a Openreach modem reset and router rest and still nothing.
