Sudden Drop In Speed
- Sudden Drop In Speed
- « Previous
- Next »
Re: Sudden Drop In Speed
10-04-2017 12:14 PM
Just to update on the 3db profile trial line has been quite stable for 26 days which is the longest so far that my line has stayed connected without any re-syncs .
03-05-2017 3:17 PM
@bobpullen Has there been any further developments in regards to the 3db trial , So far my line has remained stable for 49 days while on the 3db profile so results do look quite promising .
16-05-2017 5:52 PM
After 2 months of my line being stable on the 3db profile the line has had a resync and speed has dropped to 57Mbps IP profile was at 71Mbps for 2 months now has dropped to 57 have done the usual checks quiet line test incase of any noise on the line but cannot hear anything but noise margin has gone back up to 6db @bobpullen @Anoush as to why its reverted back considering the line had been stable for 2 months.
22-05-2017 12:01 PM
I am sorry for the delay in my response.
I've recently joined the social media team, and as such I've had to create a new forum account so I don't look at the notifications on my old account very often.
It looks like you're back down to 3db...
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 71.8 Mbps |
Upstream Speed | 16.5 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 501.4 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ; 00:00 to 23:45 |
Interference Location | Customer Premise |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
22-05-2017 12:17 PM
The line length looks a bit odd to me as its showing that the line length has increased comparing to a previous test.
22-05-2017 12:25 PM
It's only an estimated line length, not an actual measurement and its only changed by a few metres so nothing to worry about.
- « Previous
- Next »
