Stupid Question
Norrette
Stupid Question
Newbie here.  I was on D*mon and switched on today by Plusnet for Fibre.  All worked every well.  Kudos.  But I didn't see any openreach vans at the cabinet yesterday or this morning (just outside next door's house).  How do I know if I'm on fibre or not?
Fixes: 62
Re: Stupid Question
run the BT Speedtest and then further diagnostics - look at the IP Profiles
alternatively what speeds does your router report
St3
Aspiring Champion
Fixes: 5
Re: Stupid Question
Here is the bt speedtest link http://speedtest.btwholesale.com
SpendLessTime
Aspiring Hero
Fixes: 82
Re: Stupid Question
@Norrette
Or alternatively
If using the Plusnet Hub One, login into the router, click Troubleshooting, then click HelpDesk and look at the line which says Modulation.
If the number is one of these ( G.992.1 ,G.992.3,  G.992.5 ) then it is ADSL still
If (G.993.1 or G.993.2) then FTTC
Norrette
Re: Stupid Question
Thanks Spendlesstime.  I'm a 993!
The BT speed test advised not to run until router vs line speed settles - so i was going to do it later this week.
Fixes: 62
Re: Stupid Question
you can ignore that garbage as it doesn't apply to fibre
