Stuck on 60/20 profile for more than 6 months - help needed
mbanqua
Dear Plusnet,
My internet has been stuck on 60mb down and 20mb up for more than 6 months.  The connection has been rock solid for the entire time with a downstream SNR of 10 and upstream of 6.
Is there anything you can do on your end to unstick me?
Kind Regards,
J.
1 REPLY 1
zpeterk
Re: Stuck on 60/20 profile for more than 6 months - help needed
Mine is the same since 1st quarter of last year after several powercuts, I raised a ticket as previously been on 80/20 but got completetely fobbed of by the csa who said he was going the do some changes but actually did nothing.
You could try requesting a DLM reset but they probably will want to send a fitter(or as bt call it engineer) to test the line.
Good luck.
