Stuck in an endless loop - Chances of a remote DLM reset?
- Stuck in an endless loop - Chances of a remote DLM...
05-05-2015 9:56 PM
Could it be stuck? Below are snapshot graphs of the past week or so, to show you what I mean...
Anyway you get the idea. What are the chances of PN getting me a remote DLM Reset to sort this out? Connection was fine on fast path before OR came out and started disconnecting things, then never reset DLM when they left (which is the main reasonI feel it should be done remotely, as they caused DLM to interfere in the first place and should have reset it when they left!)
Thanks in advance!
EDIT: Had a blonde moment and added the images completely wrong, should be view able now!
adie:green removed images as they showed IP address
Re: Stuck in an endless loop - Chances of a remote DLM reset?
06-05-2015 9:35 AM
06-05-2015 10:04 AM
06-05-2015 10:22 AM
06-05-2015 10:26 AM
06-05-2015 12:38 PM
06-05-2015 1:23 PM
Quote from: Matthew Unfortunately it's not possible for us to do a remote reset of DLM on Fibre.
Only Openreach can do this and they'll only do it after a faults fixed on the line.
Why can't to meeting with NGA BT and ask them why they not doing remote reset of DLM on Fibre for all isp's to control themself. I do remember Chris Pettitt metion a year ago that it might happen one day.
06-05-2015 1:26 PM
06-05-2015 3:00 PM
06-05-2015 3:02 PM
06-05-2015 3:34 PM
06-05-2015 3:35 PM
Which modem are you using at the moment?
06-05-2015 4:16 PM
06-05-2015 4:16 PM
06-05-2015 4:55 PM
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 5968 Kbps, Downstream rate = 43404 Kbps
Bearer: 0, Upstream rate = 6108 Kbps, Downstream rate = 39942 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 4.5 5.8
Attn(dB): 23.5 0.0
Pwr(dBm): 12.1 1.8
VDSL2 framing
Bearer 0
MSGc: 18 33
B: 51 191
M: 1 1
T: 64 5
R: 12 16
S: 0.0414 0.9988
L: 12360 1666
D: 781 1
I: 64 208
N: 64 208
Counters
Bearer 0
OHF: 230968854 662287
OHFErr: 1075 446
RS: 3293356656 358675
RSCorr: 16084082 1409
RSUnCorr: 32538 0
Bearer 0
HEC: 7045 0
OCD: 257 0
LCD: 257 0
Total Cells: 4256314864 0
Data Cells: 3019228352 0
Drop Cells: 0
Bit Errors: 0 0
ES: 870 691
SES: 12 1
UAS: 1004 993
AS: 614730
Bearer 0
INP: 3.00 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.66 16.29
OR: 72.14 19.14
AgR: 40013.69 6127.44
Bitswap: 443021/443266 188/192
Total time = 1 days 7 hours 56 min 20 sec
FEC: 33619358 2480
CRC: 6210 857
ES: 870 691
SES: 12 1
UAS: 1004 993
LOS: 1 0
LOF: 10 0
LOM: 0 0
Latest 15 minutes time = 11 min 20 sec
FEC: 6560 1
CRC: 2 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 4674 0
CRC: 3 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 7 hours 56 min 20 sec
FEC: 230010 48
CRC: 35 11
ES: 17 10
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 2056990 124
CRC: 94 39
ES: 36 32
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 7 days 2 hours 45 min 29 sec
FEC: 16084082 1409
CRC: 1075 446
ES: 407 367
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
