Stuck Profile?
K50
Stuck Profile?
Hi
I upgraded to Fibre Broadband today,
The current link
says
Estimated line speed:80Mb (This may vary between 70.9Mb and 80Mb) -
Current line speed:80 Mb
Could i get a profile nudge
currently getting ADSL speeds
etdsaunders
Fixes: 7
Re: Stuck Profile?
Login to the hub, click disconnect and then connect again.
Should give you the correct speeds considering profile with plusnet is set correctly
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
K50
Re: Stuck Profile?
I did try that early hours of this morning,
Tried it again and still seem to be getting ADSL speeds
etdsaunders
Fixes: 7
Re: Stuck Profile?
Adsl speeds both up and down?
Any chance you could reboot the hub?
K50
Re: Stuck Profile?
yep ADSL both up and down
Yep just did a reboot and same results
Downstream: 19.77 Mbps
Upstream: 1.073 Mbps
etdsaunders
Fixes: 7
Re: Stuck Profile?
Looks like they've updated the package early and work hasn't been carried out by OR yet.
Did you get a date when fibre is due to become live?
K50
Re: Stuck Profile?
Date i was given by plusnet was the 9th
etdsaunders
Fixes: 7
Re: Stuck Profile?
So the work hasn't been carried out yet by BT. This could be any time between 8am at 11:59pm!
Providing you are using the hub one, you'll just be disconnected and when returning it'll be fibre
MattyC
Champion
Fixes: 46
Re: Stuck Profile?
Unfortunately the order won't complete today (thinking that you might been told this on webchat this morning).
The status of your order is still showing as "waiting list", so we're waiting for some ports to open up on your local cab. Hopefully we'll have this resolved soon so that you can stream on Twitch a bit better.
Matty
K50
Re: Stuck Profile?
Thanks Matty for the update,
Only thing i got told on webchat this morning was  *Fibe service has not yet been installed.and to call back after 9 to speak to the provisioning team but moving forward,
Can you confirfm i wont get charged for this package till it goes live?
as on my ticket Service Notice i have the following tickets:
Service Notice #270857484
User account type changed from Unlimited (Contracted) to Unlimited Fibre Extra
Service Notice #270857483
Dear *Name removed*
This is confirmation that your Unlimited Fibre Extra - Market 2/3 contracted service has now activated.
Contract Length: 18 Months
Service Notice #270857481
The customer has changed their service. The following discounts have been cancelled:
from 2016-05-12 to 2017-04-12
Many thanks
MattyC
Champion
Fixes: 46
Re: Stuck Profile?
We'll have to refund the difference if that's ok with you. We'll keep an eye out and sort it once you have a go-live date.
Matty
K50
Re: Stuck Profile?
So are you saying ill be paying for a Fibre package from now till then? and a refund will only be issued once i get a live date? Which could really be a while depending on when a slot opens up in a cab?
K50
Re: Stuck Profile?
If thats the case, ill rather just cancel the upgrade order since its not been completed yet by OR
and go back to my prevoius package
K50
Re: Stuck Profile?
any update on this?
MattyC
Champion
Fixes: 46
Re: Stuck Profile?
Apologies for the delay in responding. The order is cancelled and the refund is issued. I'll let you know more about that on an internal ticket.
Matty
