Streaming slow
- Re: Streaming slow
Streaming slow
29-08-2017 9:33 PM
Hi All,
Firstly, all I wanted to do with this is send an email to plusnet support but that does not seem possible as all I can do is an online chat which is now closed or phone, which I cannot be bothered with going through all the suggestions just now.
I have had plusnet for about a year now and it has been good for most of that time. The past month or so has seen a drop in performance for streaming. Every time I do a speed test it is fine, above 30Mbps (my package is 38Mbps).
Streaming services were fine to begin with but are getting slower. Now they either buffer or just reduce the quality.
What have you done to my streaming plusnet?
Wayne
Re: Streaming slow
29-08-2017 10:00 PM
I'm getting exactly the same problem.. my FTTC is the same as yours and lucky if I can run a YouTube video !!
I wonder if Plus.net support will investigate and we get a reply.. ?
Jez
Re: Streaming slow
29-08-2017 10:30 PM
Hi , well as you have found there is NO Email for Plusnet , The chat has been disabled hopefully its partially back tomorrow so your only option is holding on the phone 30mins + .
The first thing is are your testing via wifi or wired ?
Ps the staff here are good and is the best way to contact them at the moment
Re: Streaming slow
29-08-2017 10:35 PM
Good question about wired or wifi which I forgot to mention in my original post. My smart TV is wired to the router. My PS4 is using wifi but is less than a metre from the router. Then there is my mobile phone which is using wifi at any location in the house. All devices are affected in the same way with the streaming buffering or just bad quality.
It used to be so good.
I had non-fibre PlusNet years ago with no problems and hence the reason for coming back for Fibre. I am 50% of the way through my term but at the moment will not be renewing.
I had BT before and never had these problems even though it was more expensive. I would rather pay more to not have these problems.
Wayne
Re: Streaming slow
30-08-2017 7:39 AM
I have wired and wifi pc's and other devices connected and ALL are having the same issues with speed..
I have tried 3 routers / FIbre Modems including PlusNet's own one and the BT modem.. all connect at 30Mbps but stream from the web so slowly..
This has got to be a server issue at PlusNet...
I am thinking of changing back to my old ISP, as I know they are swift to deal will issues like this..
My Kids are doing my head in and we have another week of School holidays to go.....
Please PlusNet sort this out...
Re: Streaming slow
30-08-2017 10:20 AM
Re: Streaming slow
30-08-2017 10:25 AM
I don't have another router to try but someone has already replied to this thread to say they are having the same problem and have tried different routers.
I would expect the line to show no problems as I get a good line speed and normal internet surfing is fine. It is only the streaming service that is not fine. I suspect this is being slowed down by the plus net servers.
Regards
Wayne
Re: Streaming slow
30-08-2017 10:27 AM
If you really do want to rule out the router then feel free to send me a new router so that I can try it out.
Regards
Wayne
Re: Streaming slow
30-08-2017 11:54 AM
I have tried a Draytek 2860 VDSL router and a BT modem all still streaming slow..
Jez.
Re: Streaming slow
31-08-2017 10:07 AM
Further Testing...
All speed test's pass at correct speeds.. Downloading and uploading files work fine and at correct speeds.
The issue is when using social media / streaming / Gaming sites.. These either don't load or time out all the time on whatever device I am using wired or Wifi Xbox or PC or Phone..
The would seem to be to be a contention issue or routing band width limits issue.....
Any ideas why... ?
Regards
Jez
Re: Streaming slow
31-08-2017 11:14 AM
This is the same problem as I am having so thanks for joining this thread and for doing extra testing.
Wayne
Re: Streaming slow
31-08-2017 12:53 PM
I've checked the SVLAN report and there are no signs of overutilisation at the exchange.
Is your router connected into the master socket?
Which streaming sites are you having problems with?
Re: Streaming slow
31-08-2017 12:55 PM
My router is connected into the master socket.
I am having issues with Netflix, Amazon, Youtube, ITVPlayer. Basically, all of them.
Wayne
Re: Streaming slow
31-08-2017 12:58 PM
router is plugged into the master socket, no interference, have tried with all other devices removed..
Have tried different routers..
As I say download and upload speeds are fine..
It's purely :-
Facebook ( times Out)
YouTube (Buffers)
Xbox 1 and 360 disconnects from online games all the time..
If I tether my laptop to my mobile i can watch Youtube smoother than your FTTC internet access !!
I am currently connected using one of your supplied routers
Jez
Re: Streaming slow
05-09-2017 10:08 PM
Nothing has been posted due to the service coming back to normal for a few days but now it is back to the painful slow mode..
I can't even play any online games on my Xbox as it disconnects from the server before the games start !!
I am really thinking of going back to my old ISP and phone supplier as this is pants !
Jez.
