Strange speedtest.
Browni
Aspiring Hero
Fixes: 47
Strange speedtest.
My Broadband Speed Test
Not bad for a 40/2 connection Cool
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
dannyboy75
Re: Strange speedtest.
I had the same thing for a week or so recently - my download speed went up to ~ 50mbps.
I assume it's related to the new BT 55/10 product - maybe some over enthusiastic OpenReach engineers initially changed some PN customers packages too?
Sadly mine seems to have reverted to 38mbps now.
Fixes: 20
Hmmm that is strange. Can you do the test again please but do a wired connection test with wifi switched off through this link http://goo.gl/YhO9y
 Ben Babinski
Browni
Aspiring Hero
Fixes: 47
btw.PNGwhere is the speed coming from
That's wifi again, I don't think there is a way to connect wired (Acer Iconia Tab 8W running W10 Home Insider Preview)
Fixes: 20
Well that is weird because you are on 40/2 but nothing I can do but say enjoy your service.
 Ben Babinski
Browni
Aspiring Hero
Fixes: 47
Thanks Ben,
The data rate in my Hub One is 1999 / 39952  so it's confusing the heck out of me!
I remember years ago cacheing issues with an AV program caused some really silly speed test results so I downloaded a large file to prevent cacheing problems but as you can see below it is a sustainable download speed
confused.browni
