Strange issues with one game Elite
csrogue
Constantly being disconnected from elite and their support believe it may be issues with my line.  I have noticed some large jumps in latency recently, but it was more the constant drops from this particular game.
Could someone test my line for any instability.  I can then go back to them regarding the problem.  I did notice my sync speed had dropped.
Regards
R.
3 REPLIES 3
adamwalker
Fixes: 221
Re: Strange issues with one game Elite
I can see straight away that your connection is dropping out fairly frequently. It seems to be happening more in the evening and early hours of the morning so we'll need to focus on getting that fixed for you.
Line tests don't show an obvious cause but it would benefit from us investigating this with our supplier. The best thing to do next is to go back to http://faults.plus.net and complete the last few stages of a fault report then drop us another reply back here.
 Adam Walker
csrogue
Thanks, Ill complete the fault report in a moment.
I have been trying things out with elite dangerous and have found that if I run a vpn then my game connects fine and its only when I close the vpn off that I get connection issues.  They asked me to ask my isp if their service has been blocked in some way.
OskarPapa
Fixes: 65
Thanks for your reply @csrogue.
We can confirm that we haven't blocked Elite Dangerous.
Let us know when you've raised the fault and we'll get onto it right away for you.
