Stats
fred77
Stats
Just curious........do these stats look good after 2 days after reconnection?
6.76 Mbps / 27.40 Mbps
6322 / 31219
4.8 dB / 3.8 dB
44.1 dB
26.3 dB / 44.1 dB
Also just to confirm, is 4.8mb up speed?
Many thanks,
5 REPLIES 5
Fixes: 417
Re: Stats
@fred77
Whether it's good depends on what your line will support. What do you get if you put your phone number in here?  https://www.broadbandchecker.btwholesale.com/#/ADSL.
Your up speed is 6.76 Mbps.  4.8dB is the upstream Signal to Noise ratio.
fred77
Re: Stats
Thank you for replying.
Theses are the figures obtained from the link you posted.( Hope you can see them ok)
Am i right that I should be getting much higher downstream figure?
Thanks,
DSL Range A (Clean)  39.8 25 7.7 5.7 22.4 Available Available --
VDSL Range B (Impacted)  39.4 23.3 7.6 5 19.6 Available Available --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 30 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 1 -- 1 to 3.5 Available Available --
ADSL Max Up to 1 -- 0.75 to 2.5 Available Available --
WBC Fixed Rate 0.5 -- -- Available Available --
Fixed Rate 0.5 -- -- Available -- --
BET Up to 2 -- -- Available -- --
Observed Speeds VDSL
Max Observed Downstream Speed 29.03
Max Observed Upstream Speed 5.94
Observed Date 2020-06-25
fred77
Re: Stats
Just noticed as I posted the figures that it mentions FTTP as well as the other stuff! I do not have FTTP but we have been told that it will be coming soonish. Why are the figures up and down for FTTP shown on those stats?
Thanks again,
agedgopher
All Star
Fixes: 15
Re: Stats
@fred77
The FTTP that you see is FTTP on demand. This is a very expensive service with installation cost running into the thousands of pounds and very high additional charges. It is aimed mainly at business users.
Fixes: 417
Re: Stats
@fred77
No. This is the range of download and upload speeds that your line will support. That is between 25 and 39.8 down, 5.7 and 7.7 up.
39.8 25 7.7 5.7
Your measured speed falls within these limits, be they at the lower end, so as far as Plusnet will be concerned your connection is working as expected.
