Static or Dynamic?
- Static or Dynamic?
Static or Dynamic?
29-06-2015 10:26 PM
hello.
from a user point of view is using fibre any different to using normal BB (speeds excluded)?
i.e currently I have a dynamic IP and login to the routers settings, disconnect, reconnect, and I am on a new IP.
if I upgrade to fibre is it just the same? can I have a dynamic IP and will it be the same simple process to change it?
thank you.
thank you.
Message 1 of 3
(602 Views)
2 REPLIES 2
Re: Static or Dynamic?
29-06-2015 11:49 PM
Yes exactly the same, sometimes mine resets itself to issue a new ip.
Message 2 of 3
(415 Views)
30-06-2015 10:07 AM
Hi yeah it works the same, if you want a static IP though you can request one for a one off fee of £5 unless that is changing with the rest of the in coming price hikes
Message 3 of 3
(415 Views)
