Static IP
- Re: Static IP
Static IP
16-07-2015 1:19 AM
Hi
I bought the static ip add-on today and reset my router to apply..I switched off my pc a while later and returned to find my New IP had returned to the old one through IPCONFIG in cmd prompt..have i done something wrong or missed something
TIA
Wizhunter
TIA
Wizhunter
Message 1 of 5
(887 Views)
4 REPLIES 4
Re: Static IP
16-07-2015 2:28 AM
Is it showing in your Member Centre, Connection details?
Message 2 of 5
(563 Views)
Re: Static IP
16-07-2015 6:58 AM
Your IP in IP config is your LAN IP (network between router and PC)
Static IP is for your WAN IP - which you should be able to see in your router settings pages or on the member center.
Or you can check it here:
https://www.whatismyip.com/
Message 3 of 5
(563 Views)
Re: Static IP
16-07-2015 11:44 AM
Yes my new ip shows up..but i need the new ip in my PC so i can forward ports and it won't let me do it
Message 4 of 5
(563 Views)
Re: Static IP
16-07-2015 11:51 AM
Moderator Note
This discussion might be best continued here http://community.plus.net/forum/index.php/topic,141310.msg1249416.html#msg1249416
Message 5 of 5
(563 Views)
