Static IP for CCTV
- Static IP for CCTV
Static IP for CCTV
11-09-2021 3:37 PM
Hello, I have a CCTV system that I need to access remotely, however the broadband IP address keeps changing which disconnects the CCTV app. Is there a way of enabling a Static IP in the router settings or account settings. It says online that I should be able to do it but cannot find for the life of me where it is.
Re: Static IP for CCTV
11-09-2021 3:52 PM
Hi @Jonathan_A welcome to the forum.
You should be able to add a static IP via the members centre Home > Add On. scroll down you should see Static IP, if you don't see it there try Home >Broadband > Under "Help and Settings" Configure Static IP
If it's missing completely then hopefully a staffer here can do it for you
Hope this helps
Dan
11-09-2021 5:07 PM
Is it the IP address between the router and Plusnet or between the router and the camera that keeps changing ?
11-09-2021 5:40 PM
I took that to be the public IP address
Dan
11-09-2021 5:58 PM
@Dan_the_Van Unless the router is frequently re-booted neither should change, but I agree it looks like the external address. The OP would need to set up a static IP or use a DDNS service.
11-09-2021 6:47 PM
If you need a fixed IP address so that you can access your camera remotely then you need to add on a fixed IP address in your account. There is a one off charge of £5.
12-09-2021 9:12 AM
Order static IP service for one time payment £5.
BTW.
Don't forget to setup complicated password on your CCTV system otherwise you will be hacked in few minutes.
