Static IP cost
- Re: Static IP cost
Static IP cost
20-10-2020 11:20 AM
Re: Static IP cost
20-10-2020 11:23 AM
@lstegall That's it, a one off £5 fee, no monthly rip off like some other ISPs😀
How did you unknowingly set it up?
Re: Static IP cost
20-10-2020 11:37 AM
Thanks think i was just seeing what it would cost and added it.
I did try to remove it, but the browser hung so don't think I did, can you check if it is still static as I have paid the fee so will keep it then.
Re: Static IP cost
20-10-2020 11:45 AM
looks like it is still configured, thanks!
Re: Static IP cost
20-10-2020 11:47 AM
Getting static IP nowadays is like gold-dust. Plusnet are great as they only charge a setup fee, and no continued monthly rip-off that you get elsewhere. Also, most ISPs will only offer static IP on business accounts, so a double whammy!
As you have it now I would recommend you keeping it. As the world becomes more connected it opens up the possibility to putting your own devices on the Net, without traffic going via a manufacturer's server.
Regards,
Steve
