Static IP address from DSL to fibre
- Re: Static IP address from DSL to fibre
28-04-2015 8:24 PM
28-04-2015 8:37 PM
28-04-2015 10:25 PM
29-04-2015 8:12 AM
29-04-2015 8:31 AM
a) static ips were only available on unlimited fibre extra not unlimited fibre (I've read threads recently about people not being able to order extra if the PN checker doesn't believe they can get the higher speeds so I'm not sure what happens in this case, but I didn't hit this problem)
b) the existing static ip address (or block) should transfer across unchanged but this is not guaranteed (however, in my case, like others, the ip transferred across fine).
I suggest you contact PN\raise a ticket when you place the order confirming you wish to retain the IP address just to make sure.
Matthew
29-04-2015 8:43 AM
Quote from: ceridwen static ips were only available on unlimited fibre extra not unlimited fibre
http://www.plus.net/support/broadband/products/IP_addresses_broadband.shtml?source=keymatch
Quote 2. Is my IP address dynamic or static?
All current broadband products are given a dynamic address as standard, with the option of switching to a static IP.
29-04-2015 9:00 AM
From what I remember when I last thought about upgrading Nov/Dec last year, the static IP is removed initially on upgrading and given back on the account going live as fibre if requested, but could be a different IP address.
29-04-2015 10:40 AM
Quote from: ceridwen The answer I got from PN on my ticket when I asked this was that
To be blunt, that is wrong. I'm on Unlimited Fibre with a static IP.
29-04-2015 11:11 AM
Quote from: benfranklin To be blunt, that is wrong. I'm on Unlimited Fibre with a static IP.
So am I (though I already had a static IP when I changed to Fibre).
29-04-2015 11:13 AM
29-04-2015 12:35 PM
Quote from: ceridwen a) static ips were only available on unlimited fibre extra not unlimited fibre (I've read threads recently about people not being able to order extra if the PN checker doesn't believe they can get the higher speeds so I'm not sure what happens in this case, but I didn't hit this problem)
For the record, that is not true at all. I've found the ticket and fed back
Matty
30-04-2015 12:48 AM
30-04-2015 5:00 AM
