Stable speed until 21st May
schersmith
I had a good migration around March/April with excellent communication from Plusnet and BT. My speeds settled at 73Mbps, all good.
For some reason on 21st May this dropped to 66
23/05 to 63
later on 23/05 to 9.4
24/05 to 67, 52, 65
25/5 to 63
26/05 65
Router stats show
Current rate 78.9
Max rate 82.9
SNR Margin 5.9
Line att 18.6
Could you please have a quick look to see if something has changed to cause this drop - Profile?
Many thanks
Andy
8 REPLIES 8
Fixes: 419
Re: Stable speed until 21st May
How are you checking your speed? If using wifi what do you get if using an Ethernet cable?
schersmith
Thanks for your reply. The check is using Ethernet cable and Ookla which records the history. I'm wondering if the sudden drop has caused the exchange to reduce the settings or apply a reduced profile?
Andy
adamwalker
Fixes: 221
Diagnostics aren't showing any obvious issues.
I'd try the checks here next: https://goo.gl/tu2WWu
Do keep us posted.
 Adam Walker
schersmith
Adam, thanks for your reply. I have attached a shot of the Ookla results and as you can see the sudden massive drop looks like to be the cause of the reduction. Would the exchange change the settings as a result?
I have checked everything from my end and it is the same as before the drop.
From what you can see the speed profile at your end is the same as before?
Many thanks
Andy
Fixes: 419
It could be that the DLM kicked in and increased your SNR to compensate for the undefined event that caused the drop. If so, providing there’s no recurrence it should automatically recover. The time scale though is difficult to quantify.
MatthewWheeler
Fixes: 479
Can you reset today?
You should be seeing higher speeds.
 Matthew Wheeler
schersmith
Hi Matthew,
Following a reboot of router the speed has increased to just over 70Mbps - great thank you for the reset.
Hopefully all will stabilize over next few weeks.
Many thanks
Andy.
MatthewWheeler
Fixes: 479
Glad to hear that's done the trick!
Let us know if you have any further issues in future.
 Matthew Wheeler
