Speeds....
- Speeds....
Speeds....
on 18-10-2018 2:47 PM - last edited on 18-10-2018 8:30 PM by Strat
I am a FIbre Broadband user.
PN name [Removed]
The BTW test shows
Upload 12.51
Download 2.40
Ping latency 40.63
These seem to be quite appalling and an amount of web work I have to do just times out.
Any suggestions on how I can get this rectified?
Thanks, folks.
Moderator's note by Dick (Strat): Personal information removed from a public forum (to an area that staff can see).
Re: Speeds....
18-10-2018 3:03 PM
A reboot of router and modem gave me Download 14.26 / Upload 2.41 / PL 34.00, which is no good to me.
Re: Speeds....
18-10-2018 8:25 PM
Sorry to hear you're having speed issues.
Our tests aren't showing any problems with the broadband signal coming into your router.
Are your devices connecting over WiFi or straight to the router using an ethernet cable?
If you're using WiFi, would you be able to try a wired connection? This will help narrow down where the problem lies. If your connection is OK that way, then it's likely the issue lies with the wireless signal and further help can be found here: https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
If you're still having problems using a wired connection, do you experience the same issue across multiple devices?
Re: Speeds....
24-10-2018 1:52 AM
I will have a fiddle with it.
Re: Speeds....
24-10-2018 12:25 PM
