Speeds not recovered
- Speeds not recovered
22-05-2021 5:12 PM
Since the lighting storm last week and changing routers and filters my speeds are still low than what i was normally getting from 65+Mbps to now getting 48Mbps.
Can I request IP profile / DLM reset please the router connection was up for 3 days before i restarted the router and didn't show any improvement. Thanks
Re: Speeds not recovered
23-05-2021 8:50 AM
Hi there, hope you're doing well. I've run some tests on the line which appear to show no faults, with the line being in sync with download speeds of around 54.6 Mbps. The SNR ratio on the line appears to be optimal as well.
Saying that, our internal system had the connection speed capped at a lower rate than the asset profile. I've not reset this to 78Mbps which will also be reflected on your portal. Please run another wired speed test in a few hours and let me know how you get on.
-Adam - Plusnet Leeds
23-05-2021 9:44 AM
@adam945 thanks for your reply sadly I cant test wired I'm afraid my pc is up stairs but i am running on 5GHz which i do get close to what my speeds are.
23-05-2021 9:51 AM
Great stuff @mike360
Please let us know if your speeds drop again and we'll be happy to investigate.
-Adam
23-05-2021 11:01 AM
23-05-2021 12:04 PM - edited 23-05-2021 12:11 PM
@adam945 rebooted the router my speeds still same.
Router Stats:
Downstream sync speed: 57.243 Mbps
23-05-2021 12:39 PM
Thank you for getting back to me and I'm sorry to see that the speeds have not improved back where they used to be.
Can I just confirm whether you've gone through the steps which were outlined in the email I sent you on 18/05/2021? I'm just asking as we'd be happy to raise this issue with Openreach and have an engineer appointment booked, however we'd need to establish that the fault does not lie internally, as if found, a call out charge of £65.00 will be applied.
Please respond to this as soon as you can, and if everything is fine on your end, would you be happy to accept this condition prior to arranging an engineer appointment?
23-05-2021 12:49 PM - edited 23-05-2021 12:51 PM
@adam945 ive changed routers, filters and dsl cable and just done a quiet line test and there's a slight buzzing sound.
also when you say fault may lie internally is that anything beyond the master socket.
23-05-2021 1:14 PM
@mike360 Thank you for your response.
When we say internal, this means anything within the property or the surrounding perimeter outside of the Openreach domain. I'm happy to raise the fault now, however as no specific issues are being found on the line, it's extremely likely that Openreach will ask us to arrange an engineer appointment.
We're only be able to proceed with this with your acceptance that if an internal fault is found, the call out charge will be applied onto the account at a later date.
23-05-2021 1:22 PM
oh ok and yeah that fine. thanks
23-05-2021 1:43 PM
23-05-2021 1:46 PM
okay thanks
24-05-2021 6:02 PM
hi Adam iv not heard anything about what's going on with issues im having with Question [ 214373711 ] also is there any banding on line which maybe causing my slow speeds. thanks
24-05-2021 6:21 PM
Hi @mike360
Thanks for your response. The banding on the line itself seems fine, and is showing as:
0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
the speeds on the line however remain similar when previously tested. We've sent you a text message, which when responded to, will be picked up by our Technical Support Team. BT Wholesale's tests have found no issues with the line, so they'd like to arrange an engineer appointment for further investigation.
27-05-2021 12:27 PM - edited 27-05-2021 12:32 PM
