Speeds not quite what they should be
- Speeds not quite what they should be
3 weeks ago
Instead I'm getting 31Mb/s down and 1.8Mb/s Up. I've contacted support a few times, an engineer has been sent out to correct a battery fault.. but all that did was cause my connection to become spotty and the down and up to stay the exact same. Do I just need to get a new line all together or is there another fault that hasn't been figured out?
Re: Speeds not quite what they should be
3 weeks ago
@TNicholas What product have you got? Unlimited fibre is a 40 Mbps down 10 Mbps up service. Fibre extra is the faster 80/20 version. Your download speed looks as if you are on the lower speed service. As for the upload I have seen a number of posts on the forum recently where Plusnet for some unknown reason are ordering the incorrect 40 down 2Mbps up product.😲
You will need to get Plusnet to sort out the product you are receiving as it appears to be wrong.
3 weeks ago
3 weeks ago
@TNicholas Are you able to log into the router to find the modem sync speeds, it it's a HUB 1 its on diagnostics or helpdesk page ( I think) I never use ISP supplied hardware myself.
This will show your actual connection speeds to check the product you are on.
3 weeks ago
Line attenuation 27.6 - 21.0
That's all it really says on speed rates
3 weeks ago - last edited 3 weeks ago
Hi @TNicholas
These are the relevant fields. Troubleshooting >Helpdesk
6. Data rate: | |
7. Maximum data rate: | |
8. Noise margin: | |
9. Line attenuation: | |
10. Signal attenuation: |
Hope this helps
Dan.
3 weeks ago
Maximum Date Rate : 1821/35514
Noise Margin : 5.7/6.2
Line Attenuation : 27.6/21.0
Signal Attenuation : 30.8/20.9
3 weeks ago
Hi @TNicholas
Data Rate : 1837/33098 is in line with your first post where you stated I'm getting 31Mb/s down and 1.8Mb/s Up. Something is indeed wrong with your speeds.
As @RealAleMadrid indicated Plusnet for some unknown reason are ordering the incorrect 40 down 2Mbps up product and maybe your upgrade went wrong or didn't happen!?
You could wait for a staff member to see this post or raise a fault here- fault.plus.net
Dan
3 weeks ago
3 weeks ago
@TNicholas Those data rates don't look good at all, if you were on the 40/2 product I would expect rates at those speeds but you are way down, the upload is very poor so something else is wrong. The speeds are nowhere near the estimates you had.
A few questions for you. Is this the first time you have had a fibre connection? Do you have a filtered faceplate on your master socket or are you using a plug in dangly filter? Are there telephone extension sockets in the house, in use or not?
The first thing to try is to remove the front of the master socket, it may be a couple of screws or if a later version just clipped on.
This should reveal the test socket. If you connect the router to the test socket using a filter then see if the data rates you gave earlier have changed. If they haven't changed there is some other fault present.
EDIT: But yes this is the first time we've had fibre in the household
