Speeds has decreased
FIXED- Subscribe to RSS Feed
- Speeds has decreased
27-05-2016 4:39 PM
Afternoon,
I noticed my browsing had become rather slow and wasn't as fast as it normally is. Ran a speedtest.net and that was showing some confusing erratic results so I used speedtest.btwholesale.com using an ethernet cable.
The stats on the Hub One don't reflect any changes
3. Firmware version: Software version 4.7.5.1.83.8.217.1.1 Last updated 13/02/16 4. Board version: Plusnet Hub One 5. DSL uptime: 8 days, 16:18:49 6. Data rate: 14859 / 61031 7. Maximum data rate: 14616 / 59824 8. Noise margin: 5.1 / 6.1 9. Line attenuation: 21.3 / 18.1 10. Signal attenuation: 21.5 / 18.1 11. Data sent/received: 10.1 GB / 71.6 GB
Anyone know what the issue could be? There hasn't been any changes whatsoever to the set up, other than restarting the hub once which was last week.
Thanks,
NE
Fixed! Go to the fix.
30-05-2016 11:10 AM
Found that turning the router off and disconnecting the PPP session seemed to improve things.
Strange
Re: Speeds has decreased
30-05-2016 12:38 PM
31-05-2016 4:01 PM
No problem at all Harry.
