Speeds dropped after power cut, increase line profile please?
Hi Plusnet
I am normally on quite a high line profile being not to far from the exchange but we had a power cut today and my profile drop down to 63.87. It's normally 70+, is this something you could look at increasing for me? I didn't want to keep rebooting the modem incase it saw it as a potential fault and reduced the profile even more.
Appreciate your help
Kind Regards
Rufus
5 REPLIES 5
Fixes: 63
Re: Speeds dropped after power cut, increase line profile please?
Hi @iamrufus, thanks for your post.
We've amended that now and you should notice the change within the next 4 hours.
Please let us know if you need any further assistance.
Hi Oskar
Thanks very much for the prompt response I really appreciate it. Will I need to reboot either the BT modem or my router for the change to take effect or will it automatically re-sync?
Thanks again
Rufus
Fixes: 63
Hi @iamrufus, thanks for getting back to me.
Sorry - I did mean to say that a quick reboot would be required.
Let me know how you get on.
No problem, thanks for the info. Should i reboot just the router or will the bt modem need a reboot as well?
Fixes: 63
Hi @iamrufus, thanks for your response.
It's mainly to kill the ongoing session so that the new settings can take effect and so we'd recommend just rebooting the router.
