Speeds are slowing...
- Speeds are slowing...
21-12-2020 11:28 PM
I've just checked my download speeds, wired via ethernet straight into router, and I'm getting slower download speed than my Minimum Guaranteed Speed.
- Product: Unlimited Fibre Extra
- Estimated Download Range: 59 - 72Mbps
- Estimated Upload Range: 17 - 18Mbps
- Minimum Guaranteed Speed: 53.5Mbps
- Current Line Speed (Download): 49.4Mbps
is there an easy fix for this?
Thanks, Martin.
Message 1 of 2
(301 Views)
1 REPLY 1
Re: Speeds are slowing...
22-12-2020 3:31 PM
Update. the team are performing tests on my connection after I called customer services today. Quick response. 😀
Message 2 of 2
(255 Views)
