Speeds all over the place
- Speeds all over the place
27-12-2015 1:53 PM
I've been having an issue for about a week or so know where my speeds are all over the place,some days they are fine and i get around 34mbps download and 6.4mbps upload throughput but other days like today i am getting a maximum of 18.5mbps download and 1.5mbps upload throughput.
I have run the BT test and i am getting 18.5mbps download and 0,98mbps upload,i am using a wired connection and only have one device connected.
My stats are as follows
1. Product name: BT Home Hub
2. Serial number: removed
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 07/09/15
4. Board version: BT Hub 5A
5. DSL uptime: 8 days, 01:59:51
6. Data rate: 7032 / 37191
7. Maximum data rate: 7126 / 43388
8. Noise margin: 6.1 / 6.8
9. Line attenuation: 37.6 / 24.0
10. Signal attenuation: 36.5 / 21.4
11. Data sent/received: 2.6 GB / 25.0 GB
Message 1 of 2
(697 Views)
1 REPLY 1
Re: Speeds all over the place
29-12-2015 12:21 PM
I've tested your line and can't see any obvious issues, the sync rates look fine and the profile on our side is correct. If the problem continues can you report as a fault at https://faults.plus.net
Message 2 of 2
(319 Views)
