Speed way down this morning PN and BT IP profiles seem fine
xist
Surprised to find my connection so sluggish this morning -
Wired test, IP profiles both seem ok and nothing has been changed in the house, nor is there any roadworks or construction in the vicinity.
Any idea what might be up?
xist
Re: Speed way down this morning PN and BT IP profiles seem fine
OK....so have any Windows updates broken wired internet speeds? Because I've just disabled my wired connection and enabled Wifi and my speed is ok.
The only thing I've done in the last 12 hours is use windows updater and apply the recommended updates. Nothing optional or weird. Obviously this is a problem at my end, and this topic is kind of pointless now, but any ideas would be helpful. I'm assuming if the cable died last night I'd have no connection?
Fixes: 78
Hey,
I've not come across any speed issues relating to Windows 10 updates.
You might want to try updating or reinstalling the drivers for your LAN adapter.
 Adam Walker
