Speed up and Down. Is this normal at the moment?
MSW
Hi.
Over last few months (Lockdown time) speeds ranging from 0 Mbps to 31 Mbps. (BT Speed test results attached)
Can I assume this is normal with Plusnet at the moment or does anybody think it could be a problem at my end.
Router/Modem is a BT Hub6 (Type A). Have factory reset many times but to no avail.
Any help would be very much appreciated.
Many thanks.
MSW
6 REPLIES 6
daveplus
Fixes: 10
Re: Speed up and Down. Is this normal at the moment?
@MSW
Have you done the checks that are specified at https://www.plus.net/help/broadband?
Dave
ps I am not sure what is normal but my speeds are rock solid
MSW
Hi.
Thanks for reply.
Yes, done just about ALL guides/tips/checks I can find. Still problem persists.
MSW.
daveplus
Fixes: 10
So you will need to get in touch with Plusnet. Phone 0800 432 0200 and chose Technical help. I just checked and they are answering
Dave
MSW
Forgot to mention. Might be relevant.
Upload speed never seems to be affected!! See original attachments
Any ideas anybody.
Thanks.
daveplus
Fixes: 10
@MSW what did Plusnet say?
MSW
Had bit of wait on phone, so filled in a fault request online to get the ball rolling.
If and when I get more info I will be happy to share.
Many thanks.
