Speed throllted after fault
Hi all
i had an engineer as my speed had dropped below the minimum service level
bt swapped me to a new cable pair and my sync has gone from 42 to 55 Smiley
my download is stuck at 40, i had this problem before when i had a line fault
do i need to contact plusnet again or will it sort itself out, im on the unlimited fibre extra package so should work at full speed
many thanks
chris
5 REPLIES 5
Fixes: 918
Re: Speed throllted after fault
Hi Chris,
I've given things a kick this side as it looks like the profile on your account is (and now, was) stuck at the old sync rate. If you can reboot your router you should see a higher speed. Let us know how it goes. Smiley
Hi Gandalf,
thanks for the quick reply and help, but its still the same
the sync speed has raised slightly to 56358, but download speed, and speed test is still 38-39 mbits
chris
Fixes: 918
No problem Chris, it doesn't look like your connection has dropped though.
If you've tried rebooting your router can you try switching it off for around 10 mins?
Thanks Gandalf, that's sorted it.... now speed test at 52mbps
Cheers
Chris
Fixes: 918
Looks good! Thumbs_Up
Let me know if you need help with anything else
