Speed slowing, frequent dropped connection
- Speed slowing, frequent dropped connection
Re: Speed slowing, frequent dropped connection
25-04-2021 9:22 PM
I've added all your observations, and the un-cropped screen capture, to the ticket.
Will report back in due course.
PS Thanks again.
25-04-2021 9:37 PM
Something to try if you are on a static IP is to ask Plusnet to check your PN profile compared to your BT profile.
25-04-2021 9:41 PM
That is a vague possibility, @Strat , but given that it has been OK up till last month....
25-04-2021 9:42 PM
Ahem, I think the info in message 6 needs to be re-emphasised.
Get the noise on the line sorted, and you will get better speeds.
If a data tech is sent, they will fiddle with wires, reset DLM which will get your speeds back, then DLM will reduce them again. again = errrm is that not what happened!
A voice tech will listen to the line and get the noise sorted, them DLM can be reset.
Alas the days of multi skilled techs are limited..
25-04-2021 9:46 PM
25-04-2021 9:57 PM
27-04-2021 3:34 PM - edited 27-04-2021 3:35 PM
Update: (mainly for me, but anyone else who is interested!)
Still no more drop outs, and speed stable at 8mbps.
Phoned by PN.
Apologised for the "misunderstanding" with the previous operative, about what my line speed should be and PN now accept it should be up in the 35 range not the 10 openreach reports stated.
Open Reach engineer to be booked when possible to check the line.
Unfortunately, my only days off are Today & Saturday, so obviously it can't be today, so we are going to try and get one for Saturday. If not, next Tuesday.
27-04-2021 4:07 PM
Glad you appear to be getting somewhere, @worzel - and it wasn't a 'misunderstanding' with the previous operative - it was pure and simple incompetence - if I could see you should be getting the ~34/35Mbps speed, then PN should have it shouting at them.
I doubt you'll get a Saturday, but fingers crossed.
29-04-2021 8:10 PM
Interestingly, my speed randomly increased today.
Still less that it used to be, but much better that it was.
Summary of Performance Test
Timestamp: Thursday 29 April 2021 | 20:4:58
Ping: 23 Ms
Download: 21.73 Mbps
Upload: 5.36 Mbps
29-04-2021 8:14 PM
Have/had you arranged an engineer?
29-04-2021 8:25 PM
No. Nothing has been done, as far as I know.
Ticket is on hold until tomorrow, to see if PN can get a Saturday Openreach appointment.
Not sure if I should cancel that now?
As don't want them to come out, and say they found "nothing" (because it's corrected itself), and I get charged for the visit.
29-04-2021 8:33 PM
Do you still have noise on the line?
If not now, then how about when it is windy or raining?
29-04-2021 8:35 PM
Looking back, I wouldn't cancel - you have an intermittent fault.
29-04-2021 9:03 PM
Ah good point.
The noise remains, even though neither windy or raining (currently)
29-04-2021 9:15 PM
Just tell them about the noise when they come out, when that goes, you will get the speed back.
Broadband needs a quiet line for maximum speeds.
