Speed not as guaranteed
rabrodger
I had the fibre installed 2 days ago with an estimated speed of between 72mb and 80 mb and a guaranteed speed of 62 mb. Since Ive had it the speed is approx. 46mb, Ive checked all the wires, and I am using awired connection straight from the master socket. I wated to see if it would change but it hasn’t.
headonastick
Re: Speed not as guaranteed
Wow, guaranteed 62mb, I'm lucky to get 35!
rabrodger
I am pretty close to the exchange Roll eyes
Fixes: 31
Can you post the info from the Helpdesk tab from your router, being careful to hide sensitive info such as username and password?
Fixes: 190
I can see our tests are showing a potential fault which needs a engineer to visit your property to investigate further.
Can you respond to the latest update on the ticket?
 Matthew Wheeler
