The package that I am on which is the top package, says that I can could get 56 but the DSLAN has a limit of 44. How can I get this increased to that i could maybe get fast connection. See below the Fritzbox internet connection speeds.
Receive Direction Send Direction
Max. DSLAM throughput | kbit/s | 44000 | 10000 |
Min. DSLAM throughput | kbit/s | 128 | - |
Attainable throughput | kbit/s | 52789 | 8902 |
Current throughput | kbit/s | 43990 | 8902 |
Min. effective data rate | kbit/s | 43163 | |
Seamless rate adaptation | | off | off |
Latency | | fast | fast |
Impulse Noise Protection (INP) | | 43 | 0 |
G.INP | | on | off |
Signal-to-noise ratio | dB | 9 | 6 |
Bitswap | | on | on |
Line attenuation | dB | 21 | 27 |
approximate line length | m | 565 | |
Profile | 17a | | |
G.Vector | | off | off |
Carrier record | | J43 | J43 |
