Speed lower than Plusnet estimate and BT DSL Checker estimate
- Speed lower than Plusnet estimate and BT DSL Check...
- « Previous
- Next »
Re: Speed lower than Plusnet estimate and BT DSL Checker estimate
19-01-2019 12:30 PM
Although as it's not even reaching the top of the 60Mb band, increasing that upper limit to 80Mb should not make any difference.
If it gets reset, it'll probably start off with interleaving which would likely make the speed even lower.
Re: Speed lower than Plusnet and BT Estimate
19-01-2019 2:25 PM
@ejs wrote:
I doubt you would be close enough to the cabinet to even get G.fast.
"increase the speed from the port in the cabinet" is nonsense. The port in the cabinet and your modem analyse your line and the conditions and between them they work out the best speed they can manage.
Either there is no next step, or you get yourself some slightly better modem which might give you a couple more Mbps, or you go down the route of continually badgering Openreach with another 5 or so visits
That is a valid point, having read a little about G.Fast.
He definitely explained it like that, even listed off the different speeds the "ports" as he called them run at. Sadly I cannot remember the speeds he listed off.
I know some people say that is can help a little if chipset in modem/router and cab match. Having already been using Openreach HG612 and now Plusnet Hub One with little difference between the two I am not sure if another modem/router will garner any worthwhile increase. If an alternative could be had for £20 to £30 then I might be tempted.
20-01-2019 3:38 PM
I'm sorry to see that your speeds are still below the estimates for your connection and below the Minimum Guaranteed Access Line Speed.
As such we would not impose early termination fees (If applicable) if you would like to leave due to this, however I'm sorry to say there would be no further action we can take at this time to provide faster speeds on your connection.
21-01-2019 3:55 PM
As such we would not impose early termination fees (If applicable) if you would like to leave due to this.
That is not the response I had hoped for Harry and is disappointing to hear.
You will be aware that there is little point in moving to another provider using Openreach infrastructure as the problem will still be there regardless of who the bill is paid to.
21-01-2019 3:58 PM
@ejs wrote:
Either there is no next step, or you get yourself some slightly better modem which might give you a couple more Mbps, or you go down the route of continually badgering Openreach with another 5 or so visits until you get them to start swapping about sections of you line to see if they can find a better one.
@ejs - Any recommendations for modems or modem/routers to try that might help? I assume one with Broadcom chipset will be preferred?
21-01-2019 6:00 PM
Zyxel VMG8324-B10A, VMG8924-B10A or VMG1312-B10A are probably the preferred models for people who want the best modem and one that provides detailed line stats.
Anything else with a BCM 63168 chip should be slightly better than the HG612 (which has the older BCM 6368 ). That includes the BT HomeHub 5B, which might be quite cheap.
22-01-2019 9:43 PM
Anything else with a BCM 63168 chip should be slightly better than the HG612. That includes the BT HomeHub 5B, which might be quite cheap.
@ejs thanks for the info.
Prior to posting I had already seen decent feedback on the 8924-B10A and so had bagged one from that infamous auction site.
Will install that and see if it improves or makes things worse. Will report back in due course.
- « Previous
- Next »
