Speed keeps dropping to less than half that guaranteed.
FIXED- Subscribe to RSS Feed
- Re: Speed keeps dropping to less than half that gu...
14-08-2021 5:44 PM
Fixed! Go to the fix.
Re: Speed keeps dropping to less than half that guaranteed.
16-08-2021 10:27 AM - edited 16-08-2021 10:31 AM
Good morning @astare
Thanks a lot for reaching out and I'm really sorry to hear that you're getting poor speeds. first things first though, constantly restarting your router is going to be counter productive, avoid it if you can. Openreach's Dynamic Line Management System (DLM) will likely detect these disconnections and will cap the line to try and preserve stability. when you notice the speed drop, check out the Data Rate on your Hub One Manager to see what speeds the router is receiving. To do do this, follow these steps:
1. Ensure your device is connected to the router via WIFI or Ethernet, open up a web browser and type 192.168.1.254 into the URL field.
2. You should now be on your Plusnet Hub One Manager. Select Troubleshooting, then on the sub-menu, select HelpDesk. You'll then be asked to enter the admin password, which can be found on the router itself.
3. Scroll down until you find data rate, send across the values you see if you can.
You're looking for Data Rate, which is displayed as Upload Speed / Download Speed, and is displayed in Kbps. If this looks fine, the issues you're having are centred around the router / connection from the router to your devices.
Anyway, tests on the line this morning aren't showing any issues with the line, it appears to be stable and is syncing at 79<bps.
16-08-2021 11:27 AM
16-08-2021 12:07 PM
I've got to say that this is a bit of a palaver and really should not be necessary. I've never had to do this with other providers I've used in years gone by, and I suspect that this will become an all too regular routine!
I think I'll just bite the bullet and return to Virgin which is noticeably faster and totally reliable in my experience. I only left because of the increasing price, but even that is negotiable and much lower now. So I won't need your router or telephone line much longer or have to fiddle about with speed checks etc. I really pity all those punters who don't have easy access to a high speed fibre connection, it makes life so much simpler.
16-08-2021 1:13 PM
Do not forget you will have early termination charges to pay if break your contract. Your speeds look to be consistently at the maximum possible so as far as Plusnet can see from their tests your connection looks to be perfectly OK. Your low throughput speeds must have some other cause, one possibility is heavy uploading saturating the upstream connection which can cripple downstream speeds. Iphones and similar are known to cause this problem when synchronising folders by uploading to the cloud.
Also all speed tests must be over a wired ethernet connection direct to the router, any Wi-Fi or Powerline (Ethernet over Mains wiring) tests are too variable.
02-09-2021 10:45 AM
I am so fed up with this. Twice in the last few days including today, my broadband speed has dropped to less than half, in fact it's 28.9 mbps at the moment. I bought an ethernet adaptor for my mac and it makes no difference to the speed at all. I've tried to follow the directions I've been given but I cannot get into ADMIN on my router as it won't accept the password Plusnet supplied!!!
I bitterly regret signing up for 18 months, it's the worst mistake I have ever made. Can someone at Plusnet kindly sort this out for me permanently, and not expect me to perform miracles by sending reports etc. That's just a delaying tactic and really should not be necessary.
Thank you.
02-09-2021 1:18 PM
If you are talking about the access to the router, note all characters are case sensitive. If I remember correctly (I don't have a PN router), user is 'admin' - no quote marks and all lower case, and the password on the sticker on the rear/base of the router is alpha-numeric, with the letters all being upper case.
02-09-2021 1:45 PM
Thanks for getting back to us. I am sorry to hear that you are having issues with your service.
I have tested the line today and this hasn't highlighted any faults; we are still seeing a good sync speed and the connection looks to be stable other than an occasional drop which I'd assume is from you rebooting.
I am really sorry that using a wired connection hasn't made any improvement to the speed you are seeing. I would therefore advise to have a run through our troubleshooting here: https://www.plus.net/help/broadband/connection-troubleshooting/
Should this not the resolve the issue, you can log a fault for further investigation here: https://faults.plus.net
02-09-2021 1:48 PM
There's a hierarchy and if you leave both on it may well still route the speedtest through the WiFi connection.
02-09-2021 2:45 PM
02-09-2021 2:50 PM
@astare Based on the KBD check, I suspect something in your very local environment, but sight of your Help Desk tab might be useful.
02-09-2021 3:58 PM
02-09-2021 4:01 PM
Wasn't particularly what I was thinking about, but it is a better piece of kit. Let us know how it goes, if you get one.
04-09-2021 1:26 PM
Dear John,
I've just ordered a brand new and unused BT Business Smart Hub BTB EI/SI 7.00 - Item Code 088315, from ebay for £34 including postage. I could have got a cheaper one, but it wouldn't have been new and unopened.
Once I've had the chance to install and use it for about four weeks, I'll know if it's cured the regular speed drops and I'll let you know accordingly.
Many thanks for your kind advice.
Tony East
04-09-2021 1:29 PM
Cheers, Tony.😀
