Speed issues when downloading Apple updates
- Speed issues when downloading Apple updates
- « Previous
- Next »
Re: Speed issues when downloading Apple updates
29-10-2015 7:41 PM
Is this the end of the road from PlusNet - no problem found, nobody investigating any more? This causes me problems - as an Apple developer, I'm constantly downloading lots of stuff from there, both big and small, and it seems poor that I have to jump on my neighbours internet to get them in a normal time.
Not meaning to sound childish (first world problems etc!), but I will change provider if this isn't sorted out soon, and I've been more than happy with PlusNet up to now.
29-10-2015 7:49 PM
Quote from: DeclanTM Tried downloading firmware from my server so not an issue on Apple's side.
From the same Apple CDN and taking the same route as Plusnet's?
29-10-2015 7:52 PM
This slow then fast is happening at random. Using an fttp 80/20 link , Google dns servers and no other website is showing the same pattern nor slowing down at the same time.
29-10-2015 8:21 PM
back in 2010 this problem appeared and it was because everyone and their dog used the same dns servers to connect to apple's CDN so they were throttling the connections to a snails pace, so if your using google's dns servers or some other none isp servers try switching them out to bt's or virgins etc and see if its speeds up your downloads, chances are whoever your connecting to uses a different dns service to your network preference and that's the sole reason for you getting the downloads quicker /
30-10-2015 10:57 PM
Quote from: AndyH Can someone find out an Apple CDN server and post a traceroute?
No it was from Amazon EC2, it would be hard to use the same route as Plusnet as the routing is decided automatically. Was the same CDN it's clearly a hop on the Plusnet side that's the bottleneck.
30-10-2015 11:01 PM
30-10-2015 11:41 PM
31-10-2015 8:45 PM
01-11-2015 7:21 AM
03-11-2015 2:48 PM
I have a Ubiquiti Edgerouter Lite in 2 locations, one on PlusNet synced at 74down / 19up and Virgin Media 152mb down / 12 up (ridiculous)
I have a OpenVPN Site-to-Site Tunnel between the two locations.
On my PlusNet side it sometimes struggles to even stream a song from AppleMusic .... it's really frustrating.
Bear in mind these results are me on WIFI (802.11ac to Apple Airport Extreme's i have).
Doing a netstat whilst running some updates and watching a film from iTunes I don't seem to hit the Apple CDN's but Akamai :
tcp4 0 0 10.0.3.26.59280 cache.akamai.com.http ESTABLISHED
tcp4 0 0 10.0.3.26.59279 a23-62-98-169.deploy.static.akamaitechnologies.com.http ESTABLISHED
Doing a trace route to 23.62.98.169 got me:
Traceroute has started…
traceroute to 23.62.98.169 (23.62.98.169), 64 hops max, 72 byte packets
1 b1-syb-gw0-r1.net.bowers1.com (10.0.3.254) 3.276 ms 3.049 ms 1.326 ms
2 195.166.130.221 (195.166.130.221) 22.420 ms 22.954 ms 22.340 ms
3 link10-central10.pcl-gw02.plus.net (84.93.249.210) 22.517 ms 23.482 ms 23.387 ms
4 195.99.126.182 (195.99.126.182) 23.599 ms 24.242 ms 23.578 ms
5 core3-te0-2-0-15.faraday.ukcore.bt.net (213.121.193.176) 25.010 ms 24.909 ms 25.051 ms
6 peer2-et-3-3-0.faraday.ukcore.bt.net (62.6.201.165) 23.646 ms 23.551 ms 23.575 ms
7 213.137.183.36 (213.137.183.36) 23.695 ms 24.899 ms 23.640 ms
8 t2c3-xe-1-0-1-0.nl-ams2.eu.bt.net (166.49.208.218) 30.142 ms 38.006 ms 38.094 ms
9 * * *
10 a23-62-98-169.deploy.static.akamaitechnologies.com (23.62.98.169) 39.176 ms 38.658 ms 38.226 ms
When trying to stream Apple Music on PlusNet I seem to hit Apple's IP Addreses:
tcp4 0 181 10.0.3.26.59372 17.154.66.123.https ESTABLISHED
tcp4 0 0 10.0.3.26.59363 17.178.106.13.https ESTABLISHED
tcp4 0 0 10.0.3.26.57305 17.172.232.9.5223 ESTABLISHED
NetRange: 17.0.0.0 - 17.255.255.255
CIDR: 17.0.0.0/8
NetName: APPLE-WWNET
NetHandle: NET-17-0-0-0-1
Parent: ()
NetType: Direct Assignment
OriginAS:
Organization: Apple Inc. (APPLEC-1-Z)
Tracing those
traceroute to 17.178.106.13 (17.178.106.13), 64 hops max, 72 byte packets
1 b1-syb-gw0-r1.net.bowers1.com (10.0.3.254) 3.529 ms 1.668 ms 1.303 ms
2 195.166.130.221 (195.166.130.221) 22.657 ms 23.979 ms 22.227 ms
3 link9-central10.pcl-ag07.plus.net (84.93.249.209) 23.471 ms 22.259 ms 44.628 ms
4 195.99.126.138 (195.99.126.138) 25.417 ms 23.468 ms 23.691 ms
5 core4-hu0-3-0-0.faraday.ukcore.bt.net (213.121.193.164) 23.856 ms 24.860 ms 23.583 ms
6 peer2-et-10-3-0.faraday.ukcore.bt.net (62.6.201.171) 23.616 ms 24.881 ms 24.860 ms
7 213.137.183.32 (213.137.183.32) 23.618 ms 24.748 ms 24.924 ms
8 t2c1-p0-0.be-bru.eu.bt.net (166.49.208.150) 108.907 ms 108.814 ms 108.892 ms
9 * * *
10 17.0.145.68 (17.0.145.68) 182.869 ms 182.259 ms 182.938 ms
11 17.0.149.96 (17.0.149.96) 182.554 ms 183.201 ms 182.943 ms
12 17.0.148.75 (17.0.148.75) 184.671 ms 183.740 ms 183.672 ms
13-11-2015 7:20 AM
Kids couldnt use netflix, my audio book downloads were frequently getting corrupted and I'm not sure this was a PlusNet issue by Sky catchup programms (ie the internet downloaded ones) were full of pixellation in parts.
Anyway problem all sorted now!!!
Am with a new ISP - Instant 100% improvement with all above issues! AND upload speed almost x2 as fast.
Good luck to you all and hope thinks get better
- « Previous
- Next »
