Speed issues (take 3)
- Re: Speed issues (take 3)
- « Previous
- Next »
19-06-2017 2:10 PM
I don't see how a DLM reset would fix the issue in this instance as the banding is not affecting your sync speed. As your speed is so close to the estimate, it's likely no fault will be found so there is that risk of a charge.
Message 31 of 33
(347 Views)
21-06-2017 9:50 AM
Well, due to a power outage that took out the entire area my speed has gone back up to 39999! I'm just hoping DLM doesn't kick in to reduce it again due to the power outage 😛
Message 32 of 33
(321 Views)
21-06-2017 10:11 AM
Message 33 of 33
(314 Views)
- « Previous
- Next »
