Speed issues and odd connection problem
bigcal27
Just had Fibre installed, and it's mostly going great so far. Connected at 40mb, which is the package I paid for so that's all fine. I can download at 4mb/s as my speed suggests... except when I download through Usenet. I seem to only be able to get 1.5mb/s at best. I first tried changing some settings in my download client, then contacted my Usenet provider for help, and it all seems to be fine on those fronts so I'm guessing it's something with Plusnet.
Also, for some reason I am having problems connecting to Steam. If I'm downloading, Steam will NOT connected at all. If I pause a download, Steam connects. Unpause it, Steam disconnects. Any ideas why this is happening too?
bigcal27
Re: Speed issues and odd connection problem
Anyone able to help? Smiley
Plusnet Staff
Plusnet Staff
I've posted in your other thread about this, but if you could give details of your Usenet provider and settings we can take a further look.
 Tony
 Plusnet Support
bigcal27
Usenet provider is Newsdemon. Already contacted them first to see if the problem was on their end and they claim that they don't limit speeds. My friend, who lives on the same street and also has fibre, just with BT, also uses them and has the same setup as me with no problems.
I use their europe-ssl.newsdemon.com host and port 563 with SSL enabled. I have tried all of their ports and hosts, both SSL and non SSL and seen no changes.
If you need any more info just let me know.
Thanks.
aaaron
bigcal27:
I'm in a similar position, just had fibre installed and get the line speed for HTTP traffic. I get 1mB with P2P traffic. This cannot be coincidental and is certainly not the deal I signed up for. It's strange how it's not just me who is limited to such ridiculous speeds, but yourself and at least one other has posted recently regarding this.
Plusnet state on this page:
http://www.plus.net/support/broadband/speed_guide/traffic_management.shtml
"We do not apply rate limits to any of our current residential or business products."
Surely that is exactly what is in operation for P2P traffic?
Plusnet Staff
Plusnet Staff
I was going to try to replicate it, but I don't know anyone on that server. I will however see what further tests can be done for you.
 Tony
 Plusnet Support
