Speed issue
rockposer
Speed issue
My connection has gone from average 65mb down, 19mb up to 8mb down, 8mb up.
Checked everything this end, and to be honest this is the first time I've had a speed issue.
6 REPLIES 6
Oldjim
Resting Legend
Fixes: 63
Re: Speed issue
Can you post the IP profiles by clicking on Further Diagnostics in that test result
rockposer
Re: Speed issue
Oldjim
Resting Legend
Fixes: 63
Re: Speed issue
Well that rules out one thing - your line is fine
Are those tests wired or wireless
rockposer
Re: Speed issue
Wired.
I've run several tests on different pc's and using different browsers. As I said previously never had an issue before
Oldjim
Resting Legend
Fixes: 63
Re: Speed issue
unless it sorts itself out over night can you raise a fault here https://faults.plus.net
rockposer
Re: Speed issue
After re-booting my router and checking everything I pulled the plug on the BT modem and after re-starting that it seems to have fixed the issue thankfully.
