Speed has slowly dropped from 70Mbps to 60Mbps
- Speed has slowly dropped from 70Mbps to 60Mbps
12-06-2021 7:31 PM
I've had great line speed for a couple of years but lately, this has started to slow.
It used to be a pretty solid 70Mbps and has now dropped to 60 - sometimes 55.
My minimum guaranteed speed is 53.8Mbps but I'm concerned that the service is degrading more and more and will soon fall below this.
The router is fine (not using the terrible standard Plusnet router!) and I'm running over a cabled connection.
What can be done to get my speeds back up to where they used to be?
Re: Speed has slowly dropped from 70Mbps to 60Mbps
13-06-2021 12:10 PM - edited 13-06-2021 12:11 PM
Thanks for your post @Rallyepalmer and welcome to our Community Forums
I've tested your line today and I can see your router's getting a sync speed of 68mbps and there's what's known as retransmission enabled on the line (Downstream: 0.128M-80M4dB with Retransmission (High). Upstream: 0.128M-20M with no error protection) which would explain a throughput you're seeing of around 60mbps.
Retransmission is a form of error correction and it can take a bit of a bite off your download speed.
Unfortunately there isn't much we can do to bring your sync speed back up where it used to be and therefore throughput as our tests aren't showing any issues and your speed's within our suppliers expectations still.
I'd recommend plugging your router into the test socket explained Here which should rule out any internal wiring to maximise the speed your router gets from the cabinet (the green box in the road)
I've attached our testing below if you're interested in having a look
GEA Test Detail | |||
Circuit ID | NA | Service ID | [redacted] |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 64.4 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 389.3 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream traffic detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
DP Type | External | ||||
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2021-05-31T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 68.0 Mbps | 68.0 Mbps | 68.0 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2021-06-13T10:48:00Z | 2021-06-13T11:03:00Z |
Ingress Code Violation | 1 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Here's also how your connection's been doing the last 15 days or so
13-06-2021 12:41 PM
