Speed going down and ping keeps going up.
- Speed going down and ping keeps going up.
02-07-2015 3:49 PM
I hope someone from the support team can help, so i notice for sometime now my speed dropping and my ping's going up. I just did a speedtest and i got the below result few moments ago
This is from about 69Mbps and about 7ms ping's when I got the service over 18 months ago.
If anyone can help it would be greatly appreciated.
Thanks.
Thanks.
Message 1 of 8
(1,054 Views)
7 REPLIES 7
Re: Speed going down and ping keeps going up.
02-07-2015 5:53 PM
What are your results when using speedtest.net and thinkbroadband testers?
I find that the BTw speed test gives me strange results, especially latency and upload speed.
Message 2 of 8
(677 Views)
02-07-2015 6:48 PM
You have the same problem as a lot of us....They say its CROSSTALK.....I say bull...Strange we are all losing about the same!!!!
Message 3 of 8
(677 Views)
02-07-2015 7:01 PM
@Brutos
Hi - I've done a line test, and you are syncing at 71mbit so I'd expect a better throughput. I've found another fault though on your phone line, so I'm having this checked out for you.
@englishrick Only when it is!
Message 4 of 8
(677 Views)
03-07-2015 11:30 AM
@plusnettony
Thanks for your help..let me know how the test goes please on the fault on my line.
Message 5 of 8
(677 Views)
03-07-2015 1:13 PM
Message 6 of 8
(677 Views)
03-07-2015 3:07 PM
@ Matthew
Thanks for the update I will check back on Monday
Message 7 of 8
(677 Views)
07-07-2015 3:37 PM
Any update on my fault please?
Message 8 of 8
(677 Views)
